Question about Dell 12V ~ 21V AC Power Adapter for Notebook Computers Power Supply
Laptop adapter wire frayed
The power adapter for my laptop has the common problem of a fraying wire on the connector plug. Is there a better way to repair this than simply wrap electrician's tape around it? By "better" I mean something that will add some rigidity to the cord so that it won't flex as much and exacerbate the fraying.
Here's a photo of the frayed wire:
[IMG]http://i39.tinypic.com/v3pwt0.jpg[/IMG]
  • John Roshi Jan 13, 2009
    Thanks for the suggestions. I tried the shrink wrap tubing approach. But when I split the covering and heat it,
    it doesn't "shrink" or constrict around the wire. The split
    causes the tubing to actually open up.
    I guess in order for shrink wrap tubing to work as intended it
    can't be split.
  • John Roshi Jan 19, 2009
    Even better than epoxy glue, I found epoxy putty at the auto parts store. You can mould it to whatever shape you need. I wrapped some around the connector, and an hour later it's a rigid durable bond.
    Here's the repair:
    [IMGhttp://i42.tinypic.com/2cmuk60.jpg[/IMG
    Thanks!
    john
    Brigadier General:
  • 5,158 Answers
You could try some of that shrink wrap that you heat up that shrinks to covering wires after a repair a ( the proper name escapes me at the moment)... split the covering ... wrap it around the frayed part and heat it up.
Radio shack etc has the part
Posted on Jan 10, 2009
    Scholar:
  • 100 Answers
You can use Epoxie its something like super glue, but it has two substances that you mix together and they become hard as steel. just connect the wire and wrap it with little tape, then add Epoxie to make sure it sticks for ever !!!
let me know if you need anymore help :)
My power cord for the docking station is beginning to unravel with wires showing. Can it be replaced or repaired?
First, I know nothing at all about ipods. However, I am a decent electronics guy. Obviously, one end of the power cord plugs into a wall outlet; the other connects to the station. How? Does the cord simply disappear inside the station, or is there some kind of connecting plug? Which end is frayed? If it's at the wall plug end, you could simply cut the wire (unplug it first !!!) above the fray and wire in a new standard wall plug. You can do the same on the station end if the wire runs directly into the unit AND if you can get in there to reconnect the wire. If, on the other hand, the wire is attached to the station via some sort of power plug (like a printer for example), you'd better leave that puppy alone and invest in a new docking station or new power cord. You'd also better stop using the unit unless you can fix it. Bare wires spell tripped breakers and danger of injury.
May 28, 2016 | JBL ONSTAGE Docking Station for iPod
Was useing kango breaking concrete and it stopped working
Check:
  • frayed wires where it enters Kango
  • is power at switch
  • Power thru the switch
  • Frayed wires at cord plug
  • And finally - Brushes
These are the EASY checks, if none of the above, take it to your local service center.
Good Luck
Nov 09, 2013 | Hammering
Adapter or motherboard problem?
id suggest that the motherboard isn`t quite right after its fix..you can do this..Perform a Soft Reset. Power down your laptop, unplug the power adapter and disconnect any external peripheral devices. Hold down the Power button or alternate battery reset button combination for at least 10 seconds, until the laptop powers off.
Dec 19, 2017 | Thor Computers & Internet
My car's battery works but when it trys to stay on it won't it looks like theres a frayed connection of wires the copper is showing how to fix
disconnect frayed cable from battery,cut frayed part of cable off,strip insulation off end of cable attach ring connector to end of cable &reconnect to battery.
May 12, 2011 | Volkswagen Passat Cars & Trucks
Toshiba Satellite M300 won't detect power when running, will only detect it and charge battery when turned off.
If there is no problem with the battery(does it hold a full charge?) or power cabling (unnatural bunching inside the plastic sheath, frayed wires etc), then the power adapter is not providing enough current to run and charge your laptop battery at the same time. This would suggest a hardware issue with your power adapter, consider replacing it.
Oct 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
I need to replace frayed wire
You can get a new plug from any hardware store and replace the plug you have . 2 prong or 3 prong to match the original, cut the wire back just enough to get away from the frayed part ,.. when connecting the wire , curl the bare end of the wire around the screw in the direction of tightening the screw, clockwise .
thoughts?
Please Vote !!
May 14, 2010 | Breville BBL600XL. 5-Speed Blender
Wii no power no lights
I copied this from nintendo.com hope this helps you.
No Power
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
      1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
      2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
      3. While you're waiting, unplug/remove all accessories from the system (including game discs, SD Cards, Nintendo GameCube controllers, memory cards, hookup cables, and Sensor Bar). Remove all of these from the outlet and the Wii.
      4. Also check to see that controller cords, AC adapter, and Stereo AV cables/Component Video cables are not frayed and do not have exposed wires. If you find any frayed cords or exposed wires, you should replace those parts.
      5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light comes on.
      6. If the system works, plug the Sensor Bar into your system, then turn the system on to see if it still works. Repeat this process with one accessory at a time. If your system doesn't work once you've connected a particular accessory (Sensor Bar, Game Disc Nintendo GameCube controller, Memory Card, SD Card, etc.), there may be something defective with that accessory.
Aug 27, 2009 | Nintendo Wii Console
NO POWER
Did it work before?
Jul 05, 2009 | Nintendo Wii Console
Power failure
your safest bet is to replace the power cord with a new one you can short circuit your computer if the expose wire touches while its plug in just find a pc store that sell the power cord for your pc
Dec 04, 2008 | Acer Aspire 5050-3242 Notebook
Power window circuit breaker
replace the circuit breaker it could be faulty also always repair any and all frayed and damaged wires
Jun 05, 2008 | 1994 Jeep Grand Cherokee
Computers & Internet Logo
1,417 people viewed this question
Alun Cox
