Question about Whirlpool LER5636P Electric Dryer
Im installing the belt on a whirlpool LER5636JQ0 model and I am wondering do you put the grooved sided down on the drum or the smooth side..down and when you loop it through the pulley do you put the smooth side down
    Sergeant:
    Champion:
  • 262 Answers
This hard to explain in a email but i will try groov side goes towards the drum/tub come down and there is a hole in the pulley loop the belt thru the pulley and on to the motor shaft so grooves are on the shaft also and flat side of belt is riding on the left of the pulley on the outside
Posted on Jan 10, 2009
Serpentine belt diagram 2008 ford focus with no power steering
Start on bottom pulley , remember engine turns right .. go to next pulley up , if pulley is grooved install grooves in belt on pulley , next pulley , grooved or smooth , smooth use back of belt , remember clockwise around pulleys , grooved pulleys grooved side , smooth pulley back side ....
Nov 13, 2017 | Ford Cars & Trucks
Putting on a serpentine belt do the grooved side of the belt go to the grooved pulley or the smooth pulley
The grooves on the belt go with the grooves on the pulley, the belt will fold around so the smooth side of the belt runs on the smooth surface of the idlers and tensioner. If you're not sure how to route the belt, there is usually a diagram under the hood of the car or you can look it up online.
Oct 25, 2016 | Cars & Trucks
Installing drive belt on a Maytag model lde482 Dryer
http://www.youtube.com/watch?v=6ufArteqWXk
go here and this should help you.when you put the belt on the ribs are up so the smooth side touches the drum,the easiest way is rap the belt around the pulley,feel and make sure the left side of the belt is in the metal v like bracket,with your left hand grab the right side of the belt and pull it to the left to put it onto the motor shaft while with your right hand you push the pulley to the left at the same time,it's a little different from a regular whirlpool belt but you should get it,if it feels like the belt isn't long enough make sure the new belt is on the old mark on the drum.hope this helps.part number for belt is Y312959
Feb 01, 2014 | Dryers
The fan belt has come off
Grooves on the inside. You should replace it with a new one, and re-tension it.
Sep 21, 2017 | Candy Washing Machines
I just had the belt replaced on my "Maytag" Gas Clothes Dryer Model #DG608. The repair man installed the new belt with the smooth side toward the drum as per one set of instructions derived from...
Herman usualy the groove side goes toward the drum which means it rides on the pulley from the motor disconnect and lean backwards to get a visual
Apr 05, 2011 | Dryers
I have an older kenmore 70 series dryer. the belt broke and im trying to figure out where the pulley is supposed to go and how the belt is supposed to go
If you are referring to the tension pulley that keeps the belt tight on the drum, it is common for it to come loose when the belt breaks because there is no longer any tension holding it in place. Just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 24, 2010 | Kenmore Dryers
What is the correct belt routing for a maytag MDE6000AYW dryer and should the groove side or smooth side be on the drum? Thanks. dave
groove down. around the drum. near the motor you will find a tensioner. Through the tensioner then around the pulley on the motor. Have your assistnnt hold the drum up while you get up and prepare to put the front back on. You know the rest.
They call it a tensioner for good reason ... you may want to lift it using the length of a screw driver against the floor of the machine.
Watch your fingers.
If you are happy with this answer, please leave positive comments
thanks
a
Oct 14, 2009 | Maytag MDE6000 Dryer
I am installing a new belt but the pulley that mounts to the ground i found was not attached and i am not posotive of its correct spot i need a diagram
The idler pulley goes in front of motor shaft. There is two slits in sheet metal where it slides in. after pulley is on. put the belt around drum and pinch belt together. put belt under idler wheel then put end on motor shaft. You can push up on idler pulley to get around motor.Make sure grooved side of belt is wrapped around drum. Good Luck!!
Apr 24, 2009 | Dryers
I have disassembled my Whirlpool dryer and discovered the belt had come off. There was a part the is not secured fully to the dryer that has a wheel that appears to run against the belt, yet this piece...
there are 2 slots in base just under motor pulley the bracket fit into the the bracket will curve to left when installed properly..place belt around drum grooved side down..double belt at bottom and push through opening in bracket and around motor pulley roller on bracket will ride on top side of belt keeping tension on it
Aug 19, 2008 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
