Question about Acer Aspire 3610 Notebook
Usb hi speed verbatim portable disk does not work
When in try to use the verbatim portable hard disk on the acer aspire 3610 this computer does not activate "new hardware found". Nothing happens and i cannot use the device
  • jasonjohn89 Jan 31, 2009
    i have something similar to this .. i have portable hdd which works on dad's laptop but not on my desktop .. please help me solve this .. any help will be greatly appreciated
  • Bill Speer
    Bill Speer May 11, 2010
    Does the device work in any other computer? Have you tried another USB port? Another thing to check would be if it is actually being recognized by the machine. Right click My Computer and choose Manage. Under Storage, choose Disk Management and see if it's listed there in the pane on the right. If so, let me know. I'm watching the Ravens/Titans game and have the laptop beside me!
  • 4 Answers
I just found out the solution to this problem ..
Solution: go to start menu>Right-click my computer and select properties> go to the hardware tab and click on device manager> Device Manager should pop-up choose Universal Serial Bus Controllers u should see 2 or more USB Root Hub right-click it and select properties and click the power management tab uncheck "allow the computer to turn of this device to save power" it should work now
Cheers
Jasonjohn89
Posted on Jan 31, 2009
How do I use your Verbatim? Please give me instructions
From Verbatim "Installing your portable hard drive is extremely simple - just use the included mini-USB cable to connect your hard drive to any free USB port on your computer. On Windows computers, a new icon will appear in My Computer representing your hard drive. On Mac OS systems, your hard drive will appear on the desktop as a new disk."
Jun 11, 2011 | Verbatim 320GB USB Portable Hard Drive
Hi, My Verbatim 320gb will no longer be recognized by my TV, after I did a format of the harddisk with My vista. I can use it on my pc, without any problems, only it's much slower on the filesharing...
that would definite be happen because hard disk of pc is slightly different on speed (rpm), it more faster than from other hard disk use on tv, cctv capture storage disk. as long you'll satistied then use it at least you'll save some money.
Feb 18, 2011 | Verbatim 320GB USB Portable Hard Drive
Why aspire 3610 is very slow ?there is no virus!
Try removing programmes you no longer use and running Speed Disk/Defrag.
What happens is the system gets clogged with un needed garbage. A good spring clean may help.
Hope that fixes your problem.
Dec 13, 2010 | Acer Aspire 3610 Notebook
My pc doesnt recognitze my portable verbatim hard drive anymore, model 47512, and their support page sucks. what can i do?
First, try to connect it to a different computer, to see if it can be read on _any_ computer at all.
Second, check the warranty-status of the unit; if the warranty still is valid, Verbatim will replace the hardware (but will NOT make any attempts to 'recover' your files).
Third, an external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem.
Aug 20, 2010 | Verbatim External, USB 2.0, 750GB...
I bought a Verbatim Clon USB Portable HardDrive to back up files from my Mac Computer. When I click and drag, I get this pop up " items can't be move because verbatim can't be modified." It says the hard...
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Dec 19, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
My verbatim usb external hard drive quit working on only one of my computers. I tried using computer management but it doesn't recognize it there. it does show up as Toshiba in the device manager but...
The brand of your HD is Verbatim, so it should not show up as Toshiba in the Device Manager. Your computer is detecting another device.
Please do not rely on the Device Manager, you have to check the Disk Management instead. If the HD did not show up in the Disk Management, try connecting the HD into another USB ports of the problem computer. It could only be the USB ports of the problem computer is bad.
How many computers do you have? If you have 3 PCs and only one computer is having a problem, then you might need to update the USB driver of the problem computer.
Have a great day!
Sep 04, 2009 | Verbatim 160GB USB FireLite: The "drive...
Lacie 1tb external hard drive into ps3 is not regconised
I have the same issue, however with my verbatim 500g its ok. i believe it is because the lacie is a desktop external and therefore is compatable with windows xp and 7 alone.
Verbatim is a "portable" external hard drive which makes it compatible with several different systems. I would suggest returning it, I just formatted my old verbatim harddrive and set up mediaasharing. Through my router. You can actually route the lacie harddrive by going to my computer and right click the icon. Next go to share with; advanced settings and allow all. Then when you turn your ps3 on search for media servers... I would suggest to google media server for ps3 to get it all seet up. GOOD LUCK
Jun 07, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Portable hard drive won't show on desktop
it could be defective cause you might have taken the stick off while it was loading or if not you can plug it again and try opening it through My computer/ Removable disk:
Jun 19, 2008 | Verbatim VER95327 USB Hard Drive
Acer aspire 3610 not booting pass flash screen and if it does gives an error openning windows
try by changing the data cable and check the jumper setting of the hard drive
May 12, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
