Question about Hayward Super Pump 1 1/2 - Hp for In Ground Pools
Why does my haward c48l2n134b1 pool pump leak water on the bottom
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
There is a bearing between the pump motor and pump housing that tends to leak after time. Is it leaking in the shaft area?
Posted on Dec 01, 2012
  • jonbarker Dec 01, 2012
    I think it's the impeller seals I just ordered them for 9 bucks. I'll change that and if it still leaks I'll try the bearing. It looks like it's coming from where the gold motor meats the plastic housing.
  • Gary
    Gary Dec 01, 2012
    That is the ceramic seal i suggested. That should solve your problem.
2 Suggested Answers
  • 4 Answers
SOURCE: what is the normal psi on a haward sand filter
i was told that between 9 to 12 psi is normal on all pool pumps.
Posted on Jun 29, 2009
I need the capacitor part number for a C48L2n134B1
start capacitor , that's a 161 start cap, and is a real common cap, search your area for your local pool pump motor repair guy with free testing.
Aug 14, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL : C48L2N134B1 1 1/2 HP 115/230 VOLTS IT IS BROKEN AND I WANT TO KNOW WHAT MODEL I SHOULD BE BUYING TO REPLACE IT WITH. THE MODEL NUMBERS ARE DIFFERENT...
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Thanks for your interest in FixYa.com
Aug 11, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
Opened & cleaned pool. Haward 250 Heater woun't stay on.
Could be a dirty or faulty ignition sensor. This is the sensor that tells the heater that there is a flame burning normally. If that sensor gets dirty or fails, the heater thinks there's no flame even though there is and cuts the gas as a safety measure. Cut the power, remove the cover, and check all the wire connections to be sure the leads are clean and dry and snug. The ignition sensor is near the bottom. If that doesn't work, then the sensor might be faulty rather than dirty. Call a tech to replace it.
May 30, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
How do i take apart a hayward superpump 115/230V serial number c48l2n134b1?
i have a hayward 3/4 hp model c48l2n134b1 motor when i turn it on runs fine heats up and shuts off smells like somthing is burning
May 22, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
Capacitor wiring on a ao smith M#-C48L2N134B1.
contact A.O Smith they should be able to supply you with a schematic.
Oct 20, 2009 | Pool & Spa
Why does my pool motor keep burning out? I have replaced 2 new ones since march. I have a haward super pump and Emerson 2 hp motor
What is your line voltage to the motor; 115 or 230? The motors come out of the box at 230 if it is dual voltage and if you are connecting it to a 115 V line, it will overheat and eventually fail.
If you are connecting it to the correct line voltage and setting the motor to match; check to be sure your voltage is not dropping under load. Check both line to ground to ensure both lines are sound.
When replacing the motor, are the seals sound or have you replaced the pump seal at all? Is it leaking?
Are the motors failing electrically or mechanically?
Sep 26, 2009 | Water Warehouse HIGH PERFORMANCE 2 HP...
Hayward Super Pump 1 1/2 - Hp for In Ground Pools Logo
625 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
