Question about Precor EFX 546i Elliptical Version 4
Battery replacement for the 546i precor
Where is the battery located?
  • Precor Master
  • 918 Answers
3 Suggested Answers
SOURCE:
bwinton
  • 83 Answers
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Posted on Mar 19, 2010
SOURCE: where do you find the
you must have an incompetent boyfriend ... chuck him out then throw the machine out on top of him ..
Posted on Oct 07, 2010
EFX 546i eliptical battery location
The battery is usually located at the back of the machine towards the top -- there may be a circuit board on top of the battery. And the second link listed below is a technical bulletin for certain models to help prevent damage to the battery during installation.
This link will take you to the 546i models and parts list. You can also find a parts diagram but you will need to match your serial numbers to the ones listed so you can pull up the correct diagram:
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
http://www.sportsmith.net/images/Pick_Docs%5Cp0645969101-BatteryInstallationWarning.pdf
Feb 03, 2014 | Precor EFX 546i Elliptical Version 4
CROSSRAMP ON PRECOR 546i DOESNT GO UP OR DOWN
I would definitely check the battery first. The battery may not have enough charge to power everything plus the lift motor.
Here's a link to the various 546i models:
Drill it down on the left side under "narrow your search" and look for the serial number prefix. This will let you find all the correct parts and information specific to your model and serial number.
Jan 17, 2014 | Precor EFX 546i Elliptical Version 4
Precor 546i screen won't light up
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Start by checking the voltage output from the battery. I am attaching a link to a video with instructions on how to test a battery.
Video about How to Test Battery
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
Where do the batteries go on the efx 546i
Dec 31, 2013 | Precor EFX 546i Elliptical Version 4
CHARGE BATTERY ON PRECORE EFX546I
The machine recharges the battery while in use. If your battery is dead, chances are you have a battery with some dead cells. You will need to locate your battery, usually mounted under the lower electronic board. You can try a 12 volt charger, or purchase a replacement battery. Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
Oct 14, 2012 | Precor EFX 546i Elliptical Version 4
Where is the battery located in the 546i
It should be located under the lower electronic board. If you have your serial number, you can go to our Website and get a diagram of your machine. This will show you exactly where your battery is located. Precor Elliptical EFX Repair Parts Belts Wheels Pedals SPORTSMITH net
Mar 21, 2012 | Precor EFX 546i Elliptical Version 4
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
822 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
