Question about Sony Playstation 3 (PS3) Console
PS 3 I have a scrolling line going through my screen when using my PS 3. Most of the time it is not noticable but when it is it can be very annoying. I tried the system on other TV's and it still showed up. What would you recommend?thanks
    Novelist:
  • 198 Answers
Please specify if the line appears always in same spot on your display and I may be able to assist. However, please note that if your device is still in warranty it would be very adviceable to send it for a repair because if the problem is related with what I think it does, it will require dissasembling the unit in order to fix it and this will void your warranty. Please reply back with these informations and I will try to troubleshoot this for you.
Posted on Jun 09, 2007
I have a toshiba flat screen TV about 2 years old. The annoying problem is that in the middle of NCIS the characters are talking but I can't read lips. Missing the audio happens five or six time
I have noticed a similar problem and after reading a circular that arrived through the post, I am beginning to suspect it is being caused by the new 4G mobile phone networks.
The circular offered a free filter to prevent such interference.
Nov 13, 2017 | Televison & Video
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Imprecise scrolling
go to control center, mouse properties, use the wheel-tab, and set lines to scroll to 1.
Jun 03, 2009 | Logitech Cordless Mouse
Scrolling lines on monitor
Weird... if there's still warranty on the monitor see if you can get it fixed or replaced with a new one.
Mar 06, 2009 | LG W2252TQ Monitor
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Scrolling Line Propblem
You have a ground loop problem. Buy an adapter that lifts the round ground prong and poof, clean picture.
P.S. Or fix the grounding. More than likely two different ground potentials between Cable/Sat and house ground.
Feb 18, 2008 | Televison & Video
Micro Innovations USB843S KVM Manual
I had the same problem but then i remembered what my 2port kvm was like and you can hit scroll lock 2x then press the up and down arrow key to change ports and this is the same way and to get rid of the annoying scrren on top that tells you which port just hit escape, and to get the menu scroll lock twice and space bar.
Tony
Oct 22, 2007 | Micro Innovations USB843S (USB843SEA) KVM...
Lines going through my tv
1. Do you have a HDTV? 2. Did you change your settings in your PS3's Operating system? 3. What is your hookup? (HDMI, component, other?)
Jun 06, 2007 | Sony Playstation 3 (PS3) Console
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Faint Horizontal Line
Your problem could be a bad LCD screen, and beleive me will get worse with age. It could be a Driver IC is not putting out the proper drive for that matrix of TFT. If you have a warranty, stand by your guns as its not right, so call and have the servicer make it right. Good Luck PS please do not forget to rate this thread.
Oct 22, 2006 | Samsung LN-R328W 32 in. HD-Ready LCD...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
