Question about Refrigerators
Duct damper control
Where is it and how do i open it?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
Which direction should dampers be in order for the air to flow down? I bought a new house and all the hot air seems to be upstairs while it's freezing in the basement.
If you look at the end of most dampers, there is a line on the end of the shaft. this line when it is in line with the duct it is open, and when it is 90 degrees to duct it is closed. for most damper and motor, when it rotates clockwise it goes to open. and counterclockwise it shuts. default position on zone systems is open, most damper motor spring return to open. There is a allen set screw that anchors the motor to the shaft. to set up the motor and shaft, turn power off, unset set screw and rotate damper ccw and reanchor the set screw, repeat for all damper and associated motors.
Feb 13, 2014 | Goodman Manufacturing Hvac Direct R410A...
What would cause the freeze to be cooling normally and the refrigerator side to be at a temperature of 55 degrees?
all it does is the freezer gets cold,the evap fan blows cold air from the freezer into the fridge section so if the freezer is fine,check the air ducts in the fridge section,if a package or something is blocking the vent on the bottom it will get warm or also on your model you have a damper on the top where the air blow into the fridge section from the freezer,you have an electronic damper,there's a door that opens and closes to let the air in,when it's cold enough the door closes when it gets warm the door opens so either the damper is bad or the computer board that operates it is bad,also check the packages in the freezer,if you see frozen water droplets on the packages or ice on the shelves the door could have been left open and the air ducts freeze so no air can pass through,you can hit the air ducts with a hair dryer to melt them out but be careful,don't keep the heat on one spot for to long,you can damage the ducts,also when you open the freezer door you should hear the fan blowing,if not you could have a bad evap fan motor and the air isn't blowing over to the fridge section,the damper is like 45 dollars and the computer board is around 120 dollars,you can go onto the sears site,put your model number in and look at the controls and you can look up the parts.http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MCD2257HEB/3048/0165000/M0703130/00006?blt=06&prst=&shdMod= copy and paste.open the freezer door,listen for the fan no fan bad motor,if the fan is blowing either the air ducts are frozen or you have a problem with the damper or board that operates the damper,you might want to call in a tech for this if it is the damper,it's a little tricky to do this job but that's up to you.good luck and i hope this helps you out.
Sep 24, 2011 | Maytag MCD2257HE Side by Side Refrigerator
GE MONOGRAM REFER ziss420drcs FF side is 50+ degrees and freezer is -4 degrees, It is set to be 37 degrees and 0 degrees. Evap, QC, and Cond. Fan are all working. I've looked at the illustration for the...
I have the same problem. Looking through the freezer section using a mirror, I can see the damper door. I opened it with a hanger wire. It does seem to be behind the styrofoam in the fridge section. Must be a bad damper. I am not up to checking voltages. I will call for service and direct him to the problem. last time all he did was a 1 hour defrost. Maybe the door gets froozen in place? -Bob
Nov 27, 2010 | GE Monogram ZISS420DRSS Stainless Steel
Mounting screws for manual air damper interferes with damper.
What type of damper are we talking about here? a manual or barometric.
Is the damper designed to move or stay stationary. If its designed to open and close and the screws are hindering this ability, then the screws must be removed and the damper attached to ductwork by another means. The best alternative is mastic (bucket) and mastic tape. Will form an airtight bond that will be nearly impossible to break provided its applied correctly and allowed sufficient time to dry.
Jan 08, 2010 | Heating & Cooling
Zone is set to deliver AC but nothing comes out of the vents
Your duct system has dampers that separate the four zones. Even though all four sensors are working and call for a/c, you may not be getting voltage to the damper motors, which open when there is a call for a/c, and close when the call is satisfied. In certain parts of your duct system, you will find small orange or gray boxes with wires going into them. Those are the motors for the dampers. When there is a call for a/c in all four zones, check to see if you have power going to those boxes. If power is present, the motors are bad or the damper itself is stuck. If power is not present, check the master zone control.
Aug 11, 2009 | Carrier 38CKC060 Air Conditioner
Trane Heater A/C Airflow Control
i had a similar problem, and a six inch duct and inline booster fan didnt help, the room was just to far away from the furnace and ac. to save energy, i use an oil rad in the winter, and a portable ac in the summer, it works great.my house is a back split, so its a common problem. in the summer, all downstairs dampers should be closed to push the cold air upstairs ,as it will come back down anyway and the basement is cooler as it is. so if you have 4 flores, you close the bottom 2. bungalow you close the basement
Jul 22, 2009 | Heating & Cooling
Climate controls
Car manufacturers use the defrost mode as a default for safety reasons. Being they want you to be able to defrost the windshield no matter what. So when something goes wrong the system automatically goes to the defrost mode. You most likely don't have the vacuum hose connected under the dash at the climate control assy. Or if this vehicle doesn't use the vacuum hose style you may have not plugged in one of the connectors under the dash or behind the climate control assy. Good luck.
May 21, 2009 | 1997 Lincoln Continental
Manual air duct damper installation
Go down to where the ducts come out of the furnace. Identify the line you want to install damper. Open duct and drill two holes directly across from each other. Take your damper and undo the nut and washer on the one end and install in the holes you just drilled. Reattach the washer and nut and now re connect the duct seal it with duct tape and you will be good to go.
If you have 6 inch ducts get a 6 inch damper. But be sure to do everything at the beginning on the duct as to divert air to other ducts.
I have to tell you that changing your air flow could develop problems if you do very many ducts. So be very aware of what you doing. All systems are put in with air flow in mind.
May 04, 2009 | Heating & Cooling
Help me with me frige not cooling bottom GE unit.
When you close the freezer door, does the fan turn off? There isn't any thing else on my bottom mount beside the damper that regulates airflow to the refrigerator box.
You should be able to drop a string from the damper opening at the back of the refrigerator down to the duct to the freezer. If you can't there is some obstruction in that duct. I suppose it is possible there is some other mechanism in that duct on your particular model, but I can't understand what its purpose would be.
The picture below shows the vents at the back bottom of the refrigerator box that return air to the evaporator in the freezer box to be re-cooled. If these are blocked, the fan can't draw air in to be blown back up to the refrigerator, unless of course the freezer door is open. 7e3c57e.jpg
Jan 09, 2009 | GE Profile PDS22MHR Bottom Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
