Question about Onkyo TX-SR605 Receiver
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just fine for awhile but then I began losing the cable signal. The TV displayed a warning that the HDMI port I was using had lost its signal and that i should change to a different HDMI port. I switched the cable to the HDMI 4 port and it worked fine for a couple of days and then I lost the connection again. I have now connected the HD cable to the HDMI 3 port and it's working. Any idea what's wrong?
  • 10,594 Answers
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Posted on Jan 10, 2009
Need main board for sony kdl-37xbr6
There is no other way than contact the nearest authorized service center for Sony. This board is not available locally.
Feb 05, 2013 | Sony KDL-37XBR6 37 in. LCD HDTV
Sony 52" Bravia LCD will drop picture and sound for 1-2 seconds
the only thing that i can think of is that the cables and connections are bad but if that is not the case it may be the internal components of the tv. my guess is that the tv was dropped or jumbled around while transported and what happened was internal components were broken or just mixed up so go to the retailer and get a refund or a new tv. hope this helps
May 22, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Jan 15, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Cant get TV to go off of channel 2?
try menu, then set up, make sure tuning band is set to cable if u have cable or air if your using antenna, then go to auto serch for channels
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
TV not finding Digital Channels from Cable Box
I don't know where you're located but you may want to double check with Time Warner on the availibilty of an HD box. I have TWC with an HD tier package and have an HDMI out on the box that runs directly into HDMI on this TV. Hope that helps!
Jan 17, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Sony kdl-40s2000
Probably need a software upgrade. Contact Sony for that information. This would be a common fix in most sistuations when using HDMI.
Dec 30, 2006 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Onkyo TX-SR605 Receiver Logo
186 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
