Question about Samsung HLM507W 50" Rear Projection HDTV
I have diagonal lines on the picture of Samsung HLM50
Screen displays diagonal lines on screen when tv is on. Happened after bulb replacement.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Most likely bulb is not in correctly or a issue with the optical light engine this set uses
Posted on Dec 22, 2012
Noggin
  • 944 Answers
SOURCE: Diagonal lines on my screen(samsung 55" projection HDTV hcn553w)
Here's the link to the user manual; http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=32370&CDCttType=UM&ModelType=C&ModelName=HCN553W&VPath=UM/200310/20031002105141187_P55A_00054A_0410.pdf Check page 28 and 29 for convergence instructions. Give it a try to see if it makes any difference. Check page 27 for the "perfect focus" feature and see if that helps. Could you take a photo of the "diagonal lines" on the set and post it - might help? If you open a menu on the screen, does it also have the lines across, or is it clear as normal. Check page 64 for how to run the demo, and try that. Have you recently unplugged the set from the mains power supply, left it for at least 15 minutes (preferably two hours) then turned it back on? if not, try it and see if you get any change. Check page 38 for the usual video settings - play around with them and see if any significant change? Check page 39 and set the "automatic picture setting" to standard, if it isn't already, and something else if it is - see if you get a change. Check page 40 for the colour tone adjustment - probably won't change anything, but worth a play in case. Check the bottom of page 46 about channel fine tuning - reset at least a couple of channels to 00, see if that makes a difference (long shot). Does the screen itself need cleaning? recommended is just a clean dry cloth - basically have a good close look at the screen when it is both on and off, to see if there are any marks that might be causing the problem - in particular has it possibly been cleaned with a solvent or too aggressively cleaned in a diagonal direction? shine a light on it at a few angles to check, and look from a few different angles too. Check by moving or turning them on and off if any other electric or electronic items near your tv may be causing the effect - speakers perhaps. Move speakers to check. A way to check other items is to totally cut off the electric supply to the whole house for a couple of minutes, except one circuit into which you can plug the TV and a picture source. See if you get a perfect picture - if so, start switching circuits back on 1 by one until it changes. Hope this helps - I think a photo would help a lot :)
Posted on Jul 16, 2007
ctf1800
  • 4402 Answers
SOURCE: samsung HC-p4241w- replacement bulbs/screen
http://www.fixyourowntv.com/projectionclean.php
Posted on Jan 28, 2008
  • 4234 Answers
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
Posted on Aug 28, 2008
electronick
  • 505 Answers
SOURCE: Diagonal lines through the picture.
I've found the lines caused by the digital board before. Unfortunately it is expensive. I'd recommend running it on HD and it will bypass the faulty circuit. The lamp light flashes telling you the lamp is firing up. As the lamp ages, it will take longer and longer until it fails.
Posted on Dec 08, 2008
ladywinn
  • 5138 Answers
SOURCE: Diagonal lines through the picture of Samsung DLP set.
Poor solder connections, resolder convergence ICs or you may beed to replace them.
Posted on Dec 27, 2008
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
Apr 25, 2017 | Samsung Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Samsung HLR DLP TV with white lines from top to bottom. First had no picture, bulb is 10 months new, I replaced the color wheel, and just put in a used DLP Chip. Picture came back perfect, but these w
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 18, 2017 | Samsung Televison & Video
Static lines on screen
Just adjust your cable while looking at the screen, the diagonal lines will slowly disappear
May 29, 2017 | Samsung DLP HL-P5663W 56" TV
Hi
where the line is coming out? from left to right of your screen or bottom to top?
Thanks!
Dec 27, 2008 | Televison & Video
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Diagonal lines on a Samsung 46" TV
picture is ok /converg.-ok/;diagonal lines on screen; looks like waves.Appear on tv and video modes.I observed same problem on some another tv in my practic,but this case is worse.
Sep 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung TV
Hi.
Just read your list of problems The first fault (Diagonal lines & picture collapse from left & right) Sounded like either A poor connection or dry solder joint either on scan coils or scan coil plug / socket on main pcb.
If this were the case the engineer that called out should have spotted this & sorted it very easily. But you say it is still the same so what did he do ?
Did he give you a reciept with break down of what he did ? If yes please post it here for me to go over.
The sound problem you describe has thrown me a little so could you please post your tv model number on this page so I can see if this is a stock fault.
The static shocks you are getting is relatively normal & not a problem unless you are getting them off of speaker grilles or even tv casing if it is silver in colour.
I am UK based & have access to samsung technical but I will need your tv model number.
http://dysonmanuals.inc.io/
Chris.
Oct 30, 2007 | Televison & Video
Lines on the screen
i have a samsung rear projection , and it has red lines going across the screen. i put it in the back of my cuboard and went out to buty a new tv . now a few months on i got it back out to have a play with it and i coverd up the red bulb with something fireproof and now the picture is great again just that there is no red anything that is red looks a bit darker. its not great but a least its some use now and i use it in my bedroom. it mite not be much help but a least i dont have to keep it in a cuboard anymore.
Mar 15, 2007 | Toshiba 53H71 53 in. Rear Projection...
Open Questions:
Samsung HLM507W will not turn on Alright so here's the deal....I got this TV for free from a guy on craigslist. He said he couldnt get it to turn on. He replaced the lamp, it still didn't work, so he gave up and now I have it. First thing I did was try and turn it on... The TV powered up for about 5 seconds, and then the screen started to flicker all kinds of crazy colors, and it shutdown shortly after with all 3 lights blinking. I figured this probably has to do with the color wheel, so I bought a new one and popped it in. Once installed, the TV started right up, and worked for the entire duration of it being on (approx 7 hours). Now it will not turn on. Here's the startup sequence: -Push power -A couple of audible clicks, and both cooling fans energize. -Lamp does not turn on, and after about 45 seconds of having just the fans running, the TV cycles off and tries to power itself back on. -Rinse and repeat about 3 times total. -After the 3rd attempt, the TV shuts down completely and all 3 lights start blinking in front. -Pushing power does not do anything with the 3 lights blinking. TV must be unplugged and pplugged back in before sequence can be attempted again. Looking for a possible solution/troubleshoot technique. Checked the fuses and they are fine, triple checked all of the connections. Seeing as the lamp doesnt even attempt to energize, Im thinking it could be the ballast, but I'm trying not to dump money into something that might not fix the problem. Thanks for your help!
Jan 21, 2013 | Samsung HLM507W 50" Rear Projection HDTV
Samsung HLM507W 50" Rear Projection HDTV Logo
109 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
