Question about LG 55 55LW5600 3D LCD TV
55lw5600 turns on and turns right back off with a clicking sound
Yesterday while watching my LG 55LW5600 the tv suddenly shut off and kept trying to turn itself back on but all it does is turn on and the LG logo flashes on screen for less than a second then it turns off and repeats. Everytme it does that you can hear a clicking sound like a relay switching on and off.
  • verrien
    verrien Nov 30, 2012
    Thank you! I ordered another power supply board for it. Hopefully that's all that's wrong with it.
LG 55LW5600 Tv the screen no longer turns on. The power turns on but no sound OR audio come up. Main board symptoms seem to be audio still works, but no video. Could this be power board?
Might be. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Dec 19, 2016 | LG 55 55LW5600 3D LCD TV
LG 55LW5600 sometimes won't power on
you need to change a Capacitor chemical, 100 um
if you look at the Power Supply Board you will see the one been damage it cost about 0,50 pence only
Jan 23, 2014 | LG 55 55LW5600 3D LCD TV
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
No sound on hd channels only
upgrade software from lg website then try
May 15, 2012 | LG 55 55LW5600 3D LCD TV
TV turns off adn on by itself.
If the problem only happens upon update, it could be a software issue. However if it happens all the time regardless..
It's most likely a short between the start-up processor signal on the interface board and power supply or 1 of the 2 bad themselves.
You would need to pull out the board, identify those parts, and check continuity in the path. I wasn't able to find a circuit diagram online to tell you the exact location,.
If it's under warranty your best bet is to have it serviced and recommend that fix.
If many others are having the same issue the software is likely the cause and hardware with the opposite.
May 10, 2012 | LG 55 55LW5600 3D LCD TV
I have a LG 55LW5600 and when i connect the Dongle for the wireless internet after 3 minutes the tv turn off and back on by itself. what can i do?
Hi I have found out that if there has been a power outage, this can cause the LG dongle, to not see the network. What I have done is reset the network through router. Also if you have any media servers, check to see if they are corrupted, which means you may have to remove from computer and install again.
Hopes this helps
Apr 04, 2012 | LG 55 55LW5600 3D LCD TV
55lw5600 3d not working correctly. Put the tv in 3d mode and the pictures do not line up correctly.
Try to wear the eyeglass for 3D and, that is the effect of 3D mode. good day sir
Aug 21, 2011 | LG 55 55LW5600 3D LCD TV
While watching my LG 55LW5600 this morning, loud popping sounds came from the TV followed by heavy smoke. What happened?
The tv power supply board,have blown capacitors components parts most likely.Don't tries to repair this power supply board though,because a loud poping sounds and heavy smoking have many more other components dies also just not easy to be seen as capacitors parts.The tv power supply board that the board,where the tv power a/c cord plug into it.Take the tv aparts.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 13, 2011 | LG 55 55LW5600 3D LCD TV
LG 55 55LW5600 3D LCD TV Logo
269 people viewed this question
Computer Repairing
Computer Repairing
