Question about Hamat Plumbing
Low water pressure on hamat 3 3369 faucet
How to remove check valve so as to clean or where to purchase new check valve
5 Suggested Answers
SOURCE: I have a Hamat faucet that has low water pressure all of a sudden
I have the exact same faucet from Hamat and I just took it apart ...every last bit....the tabs on each part are notched so when you put it all back again...its pretty easy....I had every single part layed across the table.
(Below is the red neck way....without the special tool to take off the top key part which requires a special T tool)
now for the desembly.... under the handle is the red/blue button...unscrew carefully not to ruin the color...if it does not come out ...pry it out...mine was not so friendly....then take a small hex and stick it in the hole and unscrew a small screw....whalllaaa ...the top is off....now for the only hard part of this whole project....without their special tool your going to have to take a vice grip layed over a cotton cloth and clamp it on the top back side perpedicular....on the actual crome/stainless steel....this part will not be seen from the front.... I did scratch mine a bit ...but dont see it after the fix...remember it under the handle on the backside....then take another vice grip and cloth to the part you stick in the counter....(not the threads of course...just above) then with hulk like procedures your going to give it all.....hold with the left the base vice grip....and with the top ...crank it counter clockwise....again with the vice grip perpendicular ...on the back edge...I had to use a small screwdriver or rod to stick it across the vice grip for leverage.....erggggg....got it.
after that take note of how the part fall out.....eventuallly you might need to take out the cylinder.....remove the hose (did it at begininng) then wiggle....and pull out the cylinder...dont unscrew....back and forth in 10 degree turns as you pull out.....this is not screwed in.....Only One big screw already taken care off... the hoses connected in the interior are tough and for some wierd reason need a 10mm wrench.
Ok good luck....and by the way MINE DID NOT HAVE HOT WIRE...a part of rubber washer came loose from my plumbing under the counter and found its way to block hot water...inside the very core of the faucet....oh well ALLL DONE.... hot water for dishes...for my wife...just kidding.
Posted on Aug 09, 2009
  • 24 Answers
SOURCE: My kitchen faucet has low
If you have pressure to the shut off valves then most likely your shut off valves are not fully opening, I would recommend you replace both valves, they build up water deposits in them a lot of the times. The other possibility is the faucet itself has a water saver filter built into it. A lot of the new faucets have water savers built into them now.
Posted on Mar 16, 2011
  • 3 Answers
SOURCE: I recently removed and reinstalled my kitchen
take the unit apart, starting with the handles and check for small rocks or derbis blocking flow.
Posted on Mar 24, 2011
wentlanv
  • 710 Answers
SOURCE: I have a Hamat 3-2861
Hamat faucets aren't the kind we come across very often. They are imported from Israel and no instructions are to be had.
They are not too different from other faucets.
I have not had the opportunity to install one of these faucets, so am going by what is the norm and the exploded view. I hope I can help.
From the view, it looks like the check valve is inside the faucet hose. If you have not disassembled that far, don't be afraid to go ahead and take it apart. There isn't much you can do wrong (except maybe to not turn the water off....). Just disconnect your supply hose and go from there. You shouldn't have a problem.
If you have any trouble or questions, please reply back.
Hope this helps. Thanks,
Handie Andie
Posted on May 06, 2011
How does one eliminate an annoying, loud noise that comes from the faucet shown below. We replaced the cylinder to no avail.
A disturbed water flow causes such sounds. Since the sound propagates through the entire plumbing? The problem may be hard to pinpoint but is generally located at a valve or an endpoint.
Check that all valves are opened completely
Try removing one of the faucets and letting the water flow freely
If you can not repair - descaling or replacement.
Nov 21, 2014 | Hamat 3-3141PC Country Classic Bar Faucet...
My kitchen faucet has low water pressure both hot & cold. My faucet is a Bixby 538. I removed the spray head and the pressure is still very low. The pressure is good up to the shut off valves under...
Mar 15, 2011 | Price Pfister Plumbing
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Blanco 2.2 GPM Faucet/Side Spray#157-013ST Via Google NO PRESSUR
Try unscrewing the aerator and cleaning the screen that you'll find there. If that doesn't work then you should check the pressure under the sink by removing the cold water hose from the cutoff valve (turn it off 1st!). If the pressure there is good then try removing and cleaning the cartridge by soaking it overnight in white vinegar or consider replacing the whole faucet if it's old. You can also call Blanco and see what they'll do for you as it has a "Limited Lifetime Warranty." If the pressure at the cutoff is low it's time to call a plumber!
Jul 14, 2010 | Blanco Classic Single Handle Faucet with...
Hansgrohe Kitchen Faucet low water pressure
Try removing the aerator and handspray to clean out any debris that may have accumulated. After 8 years there could be quite a buildup if it hasn't been regularly cleaned.
May 24, 2010 | Plumbing
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: FortĀ® Single-control...
Low pressure from pull-out spray
you may try and remove one of the bobbins and see if this helps any.
Jun 27, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Mar 17, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Low water flow from kitchen faucet
Their is likely rust build up behind the valve connections to the hot and possibly cold water supply lines. Turn the water off to the house relieve the pressure and remove both valves. Once removed use a screwdriver to break up the rust. With a small bucket under both lines turn the water main back on slightly to clear rust. Replace both valves with new ones.
Jan 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Plumbing Logo
276 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
