Question about Samsung CLX 4195FW
Samsung CLX-4195FW AirPrint and scan to email issue
This printer works pretty good overall I have however two main issues with it: 1) AirPrint: it was working (when the printer wasn't sleeping) and now the printer isn't found through AirPrint anymore without any changes to the configuration.... Any idea what could cause this? 2) The scan to email doesn't seem to work. I get the test message when I configure the outgoing mail server and test it, but I always get a failed send message when i try to scan and send. Any advice? Another not critical but annoying thing is that the printer can't be reached when its sleeping, so it has to be waken up before it can be used. Isn't there some kind of wakeonlan option as on computers and other printers ? Samsung suggested to return it to check and perform a reset, is there anyway i can reset it? Returning it is a hassle and costly! Thx, RD
4 Suggested Answers
  • 2072 Answers
SOURCE: Not sending fax
Plug a phone into that line and see what happens. Let me know what happens. Plug the phone into the line that goes into the fax machine. Make sure it works and is clear. No static or noise.
Posted on Apr 04, 2008
  • 214 Answers
SOURCE: We have a Samsung SF-5100
Take the power out. hold the red button in put power back.
Posted on Oct 17, 2011
  • 12 Answers
SOURCE: How do I clean the
A machine cleanig test is available under the maintenance menu of the machine. A manual cleaning can be done be cleaning the cartridge with a soft cloth and warm water. also clean the connections between the cartridge and the main head piece ( the little copper connections on cartridge and cartridge tray) if it still does not print, the flat cable is the problem. ALL CLEANING CAN BE DONE WITHOUT REMOVING ONE SCREW.
Posted on Oct 24, 2011
I cannot connect to a network.
dear the WPS switch of printer for long approx. 30 secs. and search wifi in your laptop. it will reflect the model code. before that you have to reload the software choosing wifi connection.
Mar 10, 2015 | Samsung CLX Series CLX-4195FW MFC /...
My printer after charging the tonner it getting the msg not compatible
is the toner cartridge using a chip? if yes, you have the wrong chip inserted.
Aug 21, 2014 | Samsung color multifunct laser print...
Samsung printer CLX-4195FW Power on then: [7]
The problem is caused by the GUI OPE Controller.
Part code JC92-02505A.
After replacing, and reassembling, you need to switch the printer on, while holding down the "0" key. This puts the printer into calibration mode for the LCD touch display. Go through the sequence on the screen and then restart the printer. If you do not got through the calibration, the touch screen will not work ?
If your in Australia, you can purchase from here:
Oct 22, 2013 | Samsung Clx Series 635753716764 Clx-4195fw...
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
Multi-function Samsung CLX-3175 doesn't scan to PC
I had the same issue with Windows 7 64 bit.I managed to solve it by doing the following
1. Locate the scan2pc.exe program in C:\Windows\twain_32\Samsung\CLX3170 2. Right-click/properties - Compatibility tab. 3.Set compatibility to win xp. Set "Run as Administrator"
I also added the scan2pc.exe to the firewall allowed programs (did that for scanmgr.exe as well, but I don't think I needed to).
Works great now!
Good luck!!
Mar 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX 4195FW Logo
150 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
