Question about Sewing Machines
Have needle heating the house of the bobbin case on pfaff 1222e
Recently chaged the feeding gear on pfaff 1222e , but realised that the needle is heating on the house on the bobbing case. and dont know how to adjust. please help
  • Sewing Machines Master
  • 1,564 Answers
Rabi. Do you mean Hitting on the bobbin case/shuttle? That is a timing issue.
Posted on Nov 30, 2012
  • rabi_kaa
    rabi_kaa Dec 02, 2012
    hi, thanks for replying, the needle doesn't go through because its heating on the house of the bobbin case (I don't know if that is the shuttle). the thing that goes round and round when you turn the wheel or sew. can you please help how to move in a correct position.
  • sylviaivie Dec 02, 2012
    hi Rabi: I can tell english is not your first language... so I will try to provide clear information. Modern "drop in bobbin" machines have 3 parts. Bobbin, Bobbin carrier and Shuttle. Typically the Carrier is plastic and the Shuttle is metal with a sharp point. The problem you are discribing sounds as if the machine has gone out of Timing. This isn't really something you can do on more modern machines. To varify that the timing is off. Remove the foot, the needle/throat plate and the bobbin cover. remove the bobbin and it's carrier. Now look for the metal point on the shuttle. When timed correctly, that point should be directly behind and slightly above the eye of the needle when the needle is at it's lowest point. If the needle hits or clicks, it's definitely out of time. Your best option is to have a professional sewing machine repair person to clean, lube and re-time your machine. Good luck.
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
Mimito7
  • 128 Answers
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Posted on Apr 25, 2009
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
  • 7 Answers
SOURCE: Problem with spinning bobbin case base of my Pfaff 360 sewing mac
on lockstitch machines with rotary hooks the base[the bit the spoolcase fits in]is held in place by a retaining finger,tip machine back and you will see a long finger with a right angle lug sticking out approx 4/5mm .loosen the screw holding the finger only slightly and spin the base till the top of the base is at the 12.00clock pos.[it will help if you take needle plate off]the lug fits into the cut out of the base.then tighten finger screw and try. if base is jammed you will need a mechanic to dismantle hook and repair and retime the machine.
Posted on Jun 24, 2009
  • 632 Answers
SOURCE: PFAFF 1222E Sewing Machine (~1977). Mechanically Locked-up
You might be in "Stopmatic" mode. Check if your pressure lifter bar is in the upper most position, if it is the machine is disengage and you are set to wind your bobbin. Lower it to the 3 o-clock position this will engage the machine and the needle will operate.
Posted on Aug 10, 2009
I have a Pfaff 4.2 Quilt Expression. I am free motion quilting and the bobbin thread keeps hanging up. Any suggestions?
1. The top loading bobbin cases have small brackets to keep them from turning or moving up or down.
2. Adjust brackets with small screwdriver. Allow enough room for thread to flow through.
3. Rotate hand wheel both directions to make sure the bobbin case doesn't move around. Also, watch the thread to see if it is flowing across the top of the bobbin case.
4. You may need to slow down movement of your "free motion". Also, make sure you are using the right pressure foot.
Mar 20, 2015 | PfaFF Sewing Machines
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
Feb 12, 2014 | PfaFF Sewing Machines
Where are the oil holes in a pfaff 1222e sewing machine
There are no oil holes in a 1222e. I apply a light oil to the inside of the bobbin case and where you clip the bobbin in the machine. I also take off the top and drop a light oil on the moving shaft. I was told no other lubrication was needed by the owner.
Jan 26, 2011 | PfaFF Sewing Machines
How do I time my Pfaff 1222E. The niddle hits the bobbin holder rather than the hole in the bobbin holder
I could write up the procedure but it would be too much for me to type in. Or you can purchase the 1222E Repair Manual and download it. It's pretty easy to work on as long as you have similar tools to clearances.
Apr 07, 2010 | PfaFF Creative 7570
Cannot turn the balance wheel - new machine to me. Pfaff 1222E
You have to lower the presser foot by one click to release it from bobbin winding mode. This mode is the same as needle down while presser foot is up so you can turn your work when it needs to go a different direction.
Nov 14, 2009 | PfaFF Sewing Machines
1222e has loose lower shaft that drives the feed
You can buy the service manual from eaby or you can download it from sewingwishlist.com in pdf format. Once in a while my 1222SE would act up. It's been really good having a service manual when you need it. As far as I know all the gears can be easily replaced by loosening it's flathead setscrew.
Oct 14, 2009 | PfaFF Sewing Machines
Aug 08, 2009 | PfaFF Sewing Machines
I can't get a bobbin to wind on a pfaff 1222E It appears that a gasket is suppose to be pushed up against a gear with small teeth, but it does not move. Can it be that the gasket needs to be replaced?
You have to raise the presser bar lifter to the "A" position (highest position) to disengage the machine and set the machine to "bobbin winding" mode.
Jul 22, 2009 | PfaFF Sewing Machines
PfaFF 1222e timming is off
Setting time isn't as simple as it sounds. You'd have to follow a checklist first before you can do the setting. I could tell you but it is just too long to upload and don't know how I can post the img's. So my best advice is to buy the factory or generic repair manual.
Dec 17, 2008 | PfaFF Creative 7570
Sewing Machines Logo
155 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
