Question about Coleman Heating & Cooling
I have a EVCON furnace DGAT070BDC, the blower will not stop running even after the unit has shut-off
    Top Expert:
  • Coleman Master
  • 5,779 Answers
Make sure fan is on auto
Posted on Sep 11, 2017
SOURCE: i have an coleman evcon
i have a coleman evcon ac furnace. the unit inside works and the outside won't
Posted on Jun 17, 2008
muttandjeff
  • 359 Answers
SOURCE: Coleman Evcon furnace, blower runs
make sure the thermostat is in the auto mode if so it is more than likely the fan relay control some are built on the board some can be replaced separately
Posted on Dec 17, 2008
jumptrout51
  • 3361 Answers
SOURCE: Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Posted on Mar 11, 2009
  • 10 Answers
SOURCE: blower fan wont shut off
Try cycling the switch at the furnace to reset the blower board. If this doesn't work remove the green wire from the blower board(computer board) to eliminate a shorted t-stat or shorted wire between the furance and t-stat. If blower remains on, then blower board is shorted. I've seen all these problems.
Posted on May 04, 2009
  • 13 Answers
SOURCE: I have a EVCON furnace DGAT070BDC. I replace the
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Posted on Oct 24, 2009
I have a coleman evcon electric furnace. The blower fan runs constantly, the switch is in auto and the fans runs even when the thermostat is shut off.
Most likely on that particular electric furnace you have a fan sequencer that is closed (stuck shut). It is the black relay that you are looking at when you take off the furnace cover to access your heat strips. You should have a red wire coming from the blower motor that plugs into the side of it. If you have a ohm meter turn power off and remove wire. Check resistance across the sequencer and it should read OL. If you have resistance across it, the relay is bad. Replace it.
Nov 28, 2013 | Heating & Cooling
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Coleman evcon furnace
How old is your furnace? Does it have a circuit board that controls everything, or are there separate controls for each function?
Nov 19, 2013 | Heating & Cooling
Coleman evcon presidential
If it's a blower motor, then the contacts on the relay is welded shut and has to be manually opened.
Sep 30, 2013 | Coleman Heating & Cooling
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
I have a Coleman Evcon gas (propane) furnace. When the t-stat is switched to heat the furnace heats up but the blower will never turn on. The unit then shuts down and tries to cycle again. I have replaced...
If the unit fires but the main blower fan doesn't come on the the unit is shutting off on a temp high limit switch and it sounds like the problem is the main blower fan motor or control
Jan 18, 2010 | Coleman Heating & Cooling
I have a EVCON furnace DGAT070BDC. I replace the igniter control, the gas valve and the thermostat. Same problem continues: glow stick works, then the pilot lights works.The igniter control clicks...
Please let me know.
Oct 24, 2009 | Coleman Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
