Question about Windchaser WCUFLTI Tower Fan
I HAVE WINDCHASER WCUFLTI AND OUT OF THE BOX IT SQUEAKS AND SOMETIMES GETS TO ALMOST A SQUEEL NEED TO KNOW HOW TO MAYBE GET IT OUT SHOULD I JUST TRY LUBING IT?PLEASE HELP I LOVE THIS FAN AND I HAVE NO WAY OF GETTING A HOLD OF WINDCHASER TO GET MY WARRANTY..THE # THEY GIVE ON THE WARRANTY CARD IS NOT A GOOD #! DISSAPOINTED!!
2 Suggested Answers
SOURCE: I'm getting a squeaking noise
Not sure on the squeaking. Mines squeak to on the low and medium speed, but not on high speed. As for the cover, remove the three 'visible' screws. There are two screws in the handle, but you have to remove the plugs that are hidding the screws. Use a thin flat blade screw driver to pry the plugs. Then, the screws will be visible for removal.
Once the all the screws are off from the back cover, using a flat screw driver depress the tab above the handle; then, gently '****' downwardly (assuming the fan is standing) to remove the back cover.
Posted on Jan 27, 2011
My fan is swaying and is very wobbly. I'm trying to figure out how to fix it
First, start at the top and make sure the hanging bracket is tight against the electrical box. If your fan has a downrod, make sure the set screw is tight. Next, check the blade holder and make sure they're tight. Then check the blades screws. If one of the blade holders are bent, even a little, they would need to be replaced. And lastly, check the blades to see if they are warped. If so, they would need to be replaced.
May 14, 2015 | Windchaser WCUFLTI Tower Fan
How can i get a manual? wcuflt1 and remote control
Windchaser messed up the link to the manual. Here's the correct link (the link is case sensitive):
http://www.windchaserproducts.com/manuals/WCUFLTi_manual.htm
Oct 22, 2010 | Windchaser WCUFLTI Tower Fan
I'm getting a squeaking noise from my Windchaser WCUFLTI fan when it stands upright. If I lean it against the wall, the noise stops. I'm in the process of dismantling it, but can't get the back cover off....
Oct 04, 2010 | Windchaser WCUFLTI Tower Fan
All the leds turn on, incluiding the tower fan oscillate, But the essential doesn't work "it doesn't ventilate". What do you suggest?
check the fan if it is working.. if not ,can you hear any humming sound coming from the motor? if there is you need to remove the cover, then remove the circular fan,try to turn on the unit without a fan if the motor is running then just clean the rust in the bushing and shaft of fan by using sand paper. then put lubricant in the shaft and bushing(oil or wd40 or grease). make sure that you remember all the parts and the position of it.. good luck
Sep 13, 2010 | Windchaser WCUFLTI Tower Fan
Basically the dryer emits a squeeling sound. almost as a worn bearing would make. kinda starts out higher pitched and gradually gets to be a consistent squeel..
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 15, 2010 | Maytag Neptune MDE4000 Electric Dryer
A very noisy. What can I do? What can I do? NuTone Model QT11ONB
Sometimes the shaft on these fans gets very dry and will squeel when it is on, a little iol will help quiet the squeel. Sometimes the fan gets some dust build up and it will make a noise every revolution when the blades hit the build up., this shoiuld be cleaned.
May 05, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Windchaser air conditioner alarm light is on and it won't turn on
look at the water shut of float, as when the bottom of unit fills with water nor the bottom water float shut of gets stuck in the up position of the toggle relay itself get falty this will cause the proble you discribe
Jun 20, 2009 | Windchaser PAC9 Air Conditioner
Engine noise on area of pulleys and sometimes engine tries to sto
Don't know if this helps. Had squeel in belt area. Occasionally engine would stop when squeel got loud and sometimes engine would try to quit while going at various speeds. Found tensioner pulley was bad and changed it. Still squeeled and engine would stop when squeel got loud. This time while sitting in yard. Further checking found binding in power steering pump. Will be putting on new one tomorrow. Hope it works. Will update.
Nov 28, 2008 | 2004 Ford Freestar
Need Owners Manual/Assembly Instructions for WindChaser PHS Patio Heater
I have the exact same problem. No owners or assembly manual. Can get no response from company?
Nov 04, 2008 | Windchaser Stainless Steel Patio Heater...
Windchaser WCUFLTI Tower Fan Logo
32 people viewed this question
Top Windchaser Dryers Experts
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
