Question about Elmo Projectors Elmo TT02RX Document Camera
How do I fix the arm on an ELMO projector?
The arm is lose
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Projector takes 30-40 min to recognize signal from elmo 110xg
the resolution might not match from presenter to projector. are you using rgb, composite or s-video? the signal might not match. there might be an auto adjust on the projector to read and match the elmo's resolution. if not, the elmo may have an issue sending a powerful enough signal to the projector, and need a new main board.
Posted on Aug 10, 2009
I open image mate and the laptop says that no document camera is connected. I have changed the cords and laptop still does not read the camera. The elmo will still project an image on the projector so...
I had the same problem with a TT-12 model. Dave from ELMO provided the resolution:
1. unplug the usb cable from your PC
2. on the ELMO:
a. Press MENU > PREFERENCES > USB MODE
b. ensure that APPLICATION is selected
c. exit the MENU and reconnect the USB cable to your PC
Oct 09, 2012 | Elmo Projectors ELMO TT02RX DIGITAL...
The camera arm on my elmo tt02rx will not stay in position, but sags quickly. any easy fix for that?
1. Remove the plastic cover on the inner half of the arm. Four screws: pay attention to where the short one goes. And if you strip them, you're dead, so use a screwdriver that fits them with no slop. Take Elmo to the hardware store with you. The cover on the upper side of the arm is still clipped in, so squeeze the bottom cover in the center to free it. The knob on the end will pop out at some point, so note which way it sits.
2. You can add a bit of tension by bending the metal strap that covers the swivel joint. Remove the three screws at the inner (knob) end. Bend the metal strap to flatten it. Just a bit: you can always try a bit more bend later.
3. Put those three screws back in. THIS IS THE IMPORTANT PART, and useful for any screws in plastic or wood: back each screw off (lefty-loosey) until you feel it click into the threads in the hole. That way, you won't strip the plastic.
4. Test it. If it doesn't stay up, bend the metal strap a bit more; if it stays up, screw the cover back on - same trick backing the screws out first. Done.
Aug 09, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
My elmo document camera TT02s is showing widescreen. How do I fix that?
Not sure what you mean by wide screen. Are you viewing on a projector, TV or monitor? Or via USB to your PC?
Feel free to email me at fkemmer@vsci.com and I am sure we can assist you.
VSC is one of the largest Elmo dealers in the US. You can view the new Elmo TT-02rx at:
http://www.shopvsc.com/Elmo-TT02RX-Digital-Document-Camera-p/elm-tt02rx.htm
Nov 18, 2010 | Elmo TT02s XGA Document Camera
Where can i send a elmo to get it fixed
go to www.elmousa.com and give the service dept. a call. They can fix you up.
Aug 12, 2010 | Elmo Projectors TRV-35H Slide Projector
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call. www.elmousa.com
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
Apr 07, 2009 | Elmo Projectors ELMO VISUAL PRESENTER,...
ELMO document camera only shows documents in black and white, not color. Is there something wrong with the bulb? the camera?
My ELMO unexpectedly stops working during class. The blue power light is still lit but the ELMO is not recognized through my projector.
Any suggestions on what the problem may be?
Mar 25, 2009 | Elmo Projectors EV-200 Slide Projector
Evere 6th or 8th frame james very frustad
I have a slide jaming problem and got this from ELMO support. I have not tried it as yet. I am using 80 slide carousels.
If the unit is jamming like the way you described it may be that the arm needs to be adjusted. If you hold down the SELECT button and turn off the unit while still holding for about 20 seconds at the same time as holding up the arm, you will be able to get to a screw that can adjust the height of the arm.
Dec 20, 2008 | Elmo Projectors TRV-35H Slide Projector
Elmo Projectors Elmo TT02RX Document Camera Logo
Top Elmo Projectors Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
