Question about Rancilio Silvia Espresso Machine
Rancilio steam wand not working - Rancilio Silvia Espresso Machine
5 Suggested Answers
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
EsWorld
  • 1618 Answers
SOURCE: No steam from my rancilio silvia. unit about 2 yrs
Check the thermostats on the top of the boiler one of them tripped.
Posted on Feb 03, 2010
EsWorld
  • 1618 Answers
SOURCE: My Rancilio Silvia developed a terrible burning
Sounds like the machine needs to be descaled and the boiler and element needs to be checked.
Was the machine left on for a long time?
If yes then the element needs to be replaced.
Posted on Feb 21, 2010
EsWorld
  • 1618 Answers
SOURCE: my rancilio will not produce
Remove top panel and reset the thermostat on the boiler one of them tripped.
Posted on Apr 15, 2011
I have a rancilio epoca 1group. After I turn the steam wand off it keeps steaming. Would it need a new valve?
Hi Daren,
You could replace the whole steam valve wand but you don't need to.
The rubber grommet inside the steam valve is worn out and the tap wont close properly - that is why the steam is coming out.
You will find these parts with a commercial rancilio supplier.
Feb 28, 2017 | Rancilio Coffee Makers & Espresso Machines
Can I regulate the temp on our machine? our Rancilio machine seems to be to be running on too high a temperature. Meaning, we barely turn the steam wand on to steam milk (after the light goes off), an
Silvia has two bimetalic switches that control the boiler temperature. One for brew water and one for steam. They are not exact and they can go bad. They are cheap and easy to replace. Just Google for Rancilio parts.
A much better fix (and more expensive) is to switch to PID control. Google for Rancilio PID control. The conversion is $250+ but once you've gone PID, you'll never go back. The temperature is exact, fast, and totally under your control.
Jan 12, 2015 | Rancilio Silvia Espresso Machine
Rancilio steam wand loose not working
Rig wand! you mean steam wand?
Take lid off and see if the knob clib connection to the steam valve is come out. Otherwise, possibly the steam valve's portioning washer is hardened and stuck. BUt sound slike shaft is broken or lost connection to the valve
Oct 28, 2012 | Rancilio Silvia Espresso Machine
Steam wand leaks and no pressure.
Ok, remove the right side panel, you will see a red switch connected to the element by a metal coil, make sure power is off and unplugged, then press in red switch, you should hear a click, then open the steam wand and plug machine in and turn on, wait until you see small spurts of steam from wand before closing.
Jun 21, 2010 | Rancilio S24 Espresso Machine
My Rancilio Silvia developed a terrible burning smell. The water still comes out of the steaming wand. I have only been using the steaming wand for the last month and not the espresso maker. I have been...
Feb 20, 2010 | Rancilio Silvia Espresso Machine
How do I put the steam wand back in?...I removed it to clean and can't get it back in place?
Hi
There is a receptacle below the steam knob underneath. There are 2 o-rings in the receptacle or on the wand. Insert the wand into the receptacle, then screw the nut on until its tight. The wand should swivel.
Nov 23, 2009 | Rancilio Silvia Espresso Machine
Hi - I have a new Rancilio that I just opened today. Steam is coming but not enough water for a brew
maybe is just air in pump,try prime water on steam wand.open steam valve and press button for make espresso,keep couple seconds
Jul 07, 2009 | Rancilio Silvia Espresso Machine
Water will not come through the steam wand
Dec 07, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
55 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
