Question about Everex StepNote NC1502 Notebook
I have a everex nc1501 1st it froze up now the screen doesnt come on at all i have an everex nc1502 that won't show anything on the LCD
  • 1 more comment
  • lanphearj Jan 14, 2009
    I have an Everex nc1502 also it will not boot it powers up the cpu fan comes on hd spins up butall i get is the power light and the wireless light
  • jamienoel Jan 23, 2009
    Same problem here. I hope someone can figure it out soon or it's getting junked.
  • Anonymous Feb 05, 2009
    I have the same problem.
Lost my adapter (65w), bought a universal laptop adapter but it is rated at 90w. will this work for my everex stepnote nc1502?
Correct voltage Greg?
Then yes it will work
More Wattage means more Amperage.
Same voltage, but more Amperage
(Voltage times Amperage = Wattage )
KEEP the inside of your laptop CLEAN
Make sure you occasionally replace the Thermal Paste on the Processor (CPU), and Thermal Pad on the graphics chipset. (GPU)
Service Manual for disassembling the laptop?
Everex is out of business (To my knowledge), and I see no service manual available.
I should be able to step by step you through it, anyway; if you desire
Regards,
joecoolvette
Apr 17, 2013 | Everex StepNote NC1502 Notebook
Where can I find the recovery disks for a everex stepnote NC1502
follow this link: http://www.notebook-driver.com/everex/everex-stepnote-nc1502-notebook-windows-xp-drivers/
May 25, 2011 | Everex StepNote NC1502 Notebook
Sound device not available in Everex Stepnote NC1502
hello you will find the drivers at the below link goodluck
EVEREX STEPNOTE
Mar 26, 2011 | Everex StepNote NC1502 Notebook
Need bios password for Everex NC1502
To reset the BIOS read the information from this link: http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop the easiest method would be using Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Mar 23, 2011 | Everex StepNote NC1502 Notebook
I need to change my screen its broken
I've swapped out literally hundreds of lcds and it's always the same deal.
Remove all the screws from around the lcd outer casing, remove the plastic frame, remove the next row of screws, unplug the lcd cable to the lcd, find the part numbers on the back of the lcd and find an exact match on ebay.
If you search by that part number usually you'll save big time since most people will typically type: nc1502 lcd and the sellers know this so they'll jack up the prices ;)
Oct 28, 2010 | Everex StepNote NC1502 Notebook
My Everex Stepnote Nc1502 is not working. It just blank.
As it not be on before or for one try telling us better what exactly happen to it with symptoms is shows ok
Feb 25, 2010 | Everex StepNote NC1500 Laptop PC
Need the power jack for the Everex Everex StepNote
you may want to make sure it is not the power cord first, i thought mine was the power cord, I plugged it up to a different laptop and it worked. so it is something in the laptop..
Nov 03, 2009 | Everex StepNote NC1502 Notebook
The computer starts up but the screen is black
hi im josh in cebu phils. friend may i help you?  If that happen where your laptop starts but cannot see the display. The problem is the connection of the lcd board to the main-board. but somtimes graphic cards causes also this problem: 1. Try to check the flex connection wire from the main board to your lcd slot. be sure it is not loosen or disconnected. 2. Be sure the hinges are firmly not dislocated . good luck hope i helped you.
Mar 14, 2009 | Everex StepNote NC1502 Notebook
Whate kind of wireless 802.11b or g is in the Everex Step Note NC1502R ?
Not sure what the chipset is that it uses, but Everex host the wireless lan driver for this particular laptop on their support site at: http://www.everex.com/support/nc1502/nc1502_downloads/nc1502_downloads.htm
The download is 2.5mb and should not take too long.  When it has downloaded, double click to install.
Nov 06, 2008 | Everex StepNote NC1502 Notebook
Everex StepNote NC1502 Notebook Logo
228 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
