Question about Jazz JDC64 Digital Camera
SD Card Needs Formatted
I put in my CD card and it says it needs to be formatted. If I hit yes and go on, then if will not take a picture and is says card protect.
  • 1 more comment
  • mgstaggs371 Jan 11, 2009
    I already did this and it did not work. It is still doing the same thing. I really apprecaite the help.
  • swahealeyman Apr 19, 2009
    I am having the same problem as explained above. When i switched the security lock and went and turned the camera back on it says the card has to be formatted again. But when i select yes THIS time it says "card err". Does anyone know what could be the problem? I know that the card works because i use it in my cell phone all the time.
  • rjgaspard May 03, 2009
    With Kodak SD memory card inserted into the camera we turned the camera on. A message appears "format ----" When we say yes it tells us "card err" change card.
    the toggle switch suggested did not help.
    Still looking for solution. Have tried two cards so far. Still no success.
    Genius:
  • 1,689 Answers
Thank you for using fixya. SD cards have a security lock on the side that you can toggle left to right or up and down.Check your card if it is on the secure mode or not, or you can just toggle the switch then check if it will start saving captures from your camera.
Posted on Jan 10, 2009
  • marlon john madrid
    marlon john madrid Jan 11, 2009
    Thank you for replying and not a problem. at this point it is best if we isolate the issue by using another SD card to check if it is the cart at fault or a part of the camera
When trying to playback photos from SD Card, the message "cannot playback image" is displayed. Happens when using more than one SD card, which rules out that it is the SC card that isn't working.
which rules out that it is the SC card that isn\'t working Not necessarily, switching SD memory card from one camera to another without formatting isn't going to happen. If the SD card was new and not formatted in the camera that it's going to be used in then there could be a lot of different errors occurring. Also if pictures were downloaded from the memory card to the computer and the card not formatted this will cause a problem as well. If you have been deleting the pictures files then again this could be a problem the card needs to be formatted. Another IF is if you downloaded pictures from the computer to the SD card and then put it back in the camera without formatting then it's not going to acknowledge the card. If you formatted the SD card in the computer then it's not going to work or work properly in the camera. Picture files can go from the camera to the computer but not back again because the computer operating system and software is not compatible with the camera firmware. It all comes back to format the memory card in the camera you are using it in before taking pictures.
Feb 08, 2011 | Canon EOS 550D Rebel T2i Digital Camera
I have put a new sd card in my camera,and its says memory is full. What could be wrong.
A few things can be happening first the SD card may have the lock switch in the lock position I'm including a diagram to show the correct positioning.
The next thing is you said you put a new SD card in. All memory cards need to be formatted to the camera they are going to be used in formatting cleans the card (yes I know it's new) and makes it compatible to the camera. Also each time you download pictures to the computer the memory card needs to be formatted to re clean the memory card and make it ready to accept new pictures. One other thing your camera has a small capacity in todays standards and the largest SD card I see being used is a 256mb, if the new card is larger then 256mb this could be the problem as well. If this is the case then it might be possible to update the camera firmware. However it would be a whole lot easier to purchase a 256mb card. Format the new card making sure the lock is in the right position and continue on as you have been.
Jan 05, 2011 | Kodak EasyShare C330 Digital Camera
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
When i put my sd card into my camera it needs to be formatted
Having received no response in over a month, I assume this is no longer a problem.
Jun 04, 2010 | HP Photosmart E327 Digital Camera
I accidentally formatted my sd card and lost pictures also the ones that were locked how can i recover all of them
dont worry, pictures lost after reformatted sd card can be recovered with sd card photo recovery software, you can download the picture recovery software from
http://www.asoftech.com/apr/
May 10, 2010 | Kingston 2GB Secure Digital Memory Card
We took our 512 mb SD Card out of our camera to download some of the pictures to a digital picture frame. When we return the SD Card to the camera amessage appears "memory card requires formatting. I know...
You can either use a separate card reader to download to your computer, or , take the card to a Walmart store and insert the card into a Kodak Picture Kiosk machine and print the pics or make a cd of them. Then, format the card in the camera.
Apr 22, 2010 | Kodak EasyShare CD40 Digital Camera
My camera wont let me use an sd card
There have been two other posts in this camera's forum about this problem, you could've saved yourself a lot of trouble by reading through the other posts.
This camera only supports an SD card of 1GB maximum. The specifications on page 25 of the User's Manual state that only SD cards between 8MB and 1GB in size can be used in this camera. When I tried a larger-capacity 2GB SD card in this camera it reported that the card needed to be formatted even though the SD card worked fine in my desktop PC's SD card slot. Verify that the capacity of the SD card you're trying to use is 1GB or less.
Feb 10, 2010 | VuPoint DC-M306AT-VP Digital Camera
Sd card will not format
The camera has a limit of a 2 GB card , its built into the camera hardware.
Oct 19, 2007 | Kodak EasyShare Z740 Digital Camera
Jazz JDC64 Digital Camera Logo
184 people viewed this question
Top Jazz Cameras Experts
pontelemon
pontelemon
Computer Links
Are you a Jazz Camera Expert? Answer questions, earn points and help others
