Question about Jensen Televison & Video
Help with VR185 remote
We have a remote with new battery that goes on the steering wheel but nothing works. Is there any trouble shooting that could help us see if this remote still works.
    Top Expert:
  • Jensen Master
  • 12,223 Answers
Use the same type batteries full charge, same marke do not use another mixed example SONY+EVERYREADY. same polarity
2) clean the contacts batteries with c.cleaner very well
3) tight the spring contacts with pliers very well
4) open the r.control and clean the keypads with c. cleaner see the diagram attached.
try again, otherwise you must go to the repair shop TV for fix it.
God bless you
Posted on Nov 29, 2012
  • Susan Graham Dec 01, 2012
    Your suggestions did help, we got it working except for one button. thank you
2 Suggested Answers
  • 89 Answers
SOURCE: Remote stops working at Welcome to your remote.
Hey,
The link below actually got my Harmony 550 working properly. I hope this helps you!!!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10746
-Kennedy
Posted on Feb 28, 2010
Powering steering trouble shooting
1.Steering wheel is hard to turn : ... The power steering box or rack or power steering pump is bad: Repair or replace steering gear or pump as required. The fluid level in the power steering reservoir is low: Fill fluid to proper level. The power steering drive belt is damaged or broken: Replace power steering drive belt.
Car Power Steering Diagnosis and Troubleshooting - AUTOINTHEBOX
blog.autointhebox.com/car-power-steering-diagnosis-and-troubleshooting.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Powering+steering+trouble+shooting
Dec 12, 2016 | Cars & Trucks
My remote won't work even with new batteries can I trouble shoot this?
test a infra red remote by turning on your cell phone camera , pointing the remote at the camera lens and pressing buttons a white spot will appear in the photo of the camera if the remote is working
Nov 26, 2016 | Televison & Video
How can I trouble & fix my scooter
hi sounds like youre circuit has shut down if your have had it in free wheel it will shut down all the lights will work take the key out put it in drive and put the key back if it has a similar circuit as a pride XL it should work...........one more thing if u leave the key turned on for 20 minutes the circuit will shut down all the lights will work take key out wait for a few minutes & put the key back in ..if this does nothing get youre batteries checked with a ..battery load tester .....good luck
Sep 05, 2015 | Pride Hurricane 4 Wheel Personal Mobility...
Trouble shoot Security system 1998 Range Rover
Sounds like the contact in the key remote has been shorted or broken. It has happened to many of my remotes. If you shake it does it sound like something is rattling around inside? If so, its unfortunately broken and you need a new one.
Nov 20, 2012 | 1998 Land Rover Discovery
Lost all electrical power no lights, no starter nothing ,battery has full charge on a 2003 500 sportsman machine was running when lights went out and lost all power . It will start and run manually. How do...
battery connections for tight -behind the switch /controls on steering shaft is a fuse /breaker check connections and condition also there is a fuseable link by the battery going towards the engine if good than test switch and connections from battery
Jan 19, 2011 | Polaris ATV
Hi.. I have a Renault Laguna 1996 2.2 diesel..fitted new battery and radio wont work...tried to enter code, but all i get is CODE..THEN 0000, but using the back wheel on hand lever at steering-wheel...
These are the usual instructions for a Renault with a Steering Wheel Remote Control
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬ ] button for up to 10 seconds to store the code
Here is another method if the Steering Remote does not work
These are  the working Code Entry Instructions if the Renault does NOT have the Steering wheel Remote Control
Keep pressing  the Preset [1] for the correct first digit
Keep pressing  the Preset [2] for the correct second digit
Keep pressing  the Preset [3] for the correct third digit
Keep pressing  the Preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the Preset [6] to save it.
Dec 01, 2009 | Car Audio & Video
2005 Sierra 4wd is not working properly
we ended up taking it to the dealership, it was a sensor.
Jan 28, 2009 | 2005 GMC Sierra
Left running lamps, cruise control, horn do not operat and air bag dash light on
Hello.Is your ABS light on?Do you hear a click noise when you turn the steering wheel?If it is,you probably have a faulty clockspring. That electronic piece controls all of those things. The clockspring is located behind the steering wheel. You have to remove the steering wheel in order to access the clockspring. MAKE SURE that the steering wheel is straight ahead before you remove it.
Sep 23, 2008 | 1998 Chrysler Town & Country
Televison & Video Logo
67 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
