Question about Kenmore Dryers
When I puch the start button on my kenmore electric dryer the only thing that happens is the timer makes a tick tocking noise. any suggestions?
After pushing the start button the timer is working but nothing else.
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
shinn8
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
localwonder
  • 6784 Answers
SOURCE: when you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Posted on Feb 14, 2009
lhendrix04
  • 11 Answers
SOURCE: Kenmore electric dryer won't start
DOOR SWITCH
Posted on Apr 20, 2009
pride applia
  • 232 Answers
SOURCE: Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Posted on Jul 01, 2009
heatman101
  • 43501 Answers
SOURCE: kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 29, 2010
Dryer drum want turn
I am hoping the problem is the belt. One way to tell is to put your ear to the machine and start it, and see if you can hear the mortor whirring. You should. If so, the machine should be needing a new belt. Most belts last about 5 years. If there is no noise of the motor, you may have either a defective door swirtch ( they are cheap plastic) or you may have an electrical issue.
Be blessed.
Jun 15, 2013 | Kenmore Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Kenmore dryer makes the ticking noise but when we push the button to start the dryer it wont start. What should we look at?
Please check your Thermo fuse
and ticking noise should not be there unless the dryer is on which means that your timer is acting up
Oct 30, 2010 | Dryers
Timer ticks, but dryer does not run
Sounds like door switch. Open door and push on door switch. you should here a clicking noise. If you can open the top of the dryer. put the 2 wires together of the door switch. Make sure it is unplugged when doing this. Make sure you use electrical tape when you put it together. Temp fix. Get a new switch
Oct 23, 2009 | Kenmore 62602 Electric Dryer
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Kenmore 90 series won't start timer ticks
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Won't start
IF ELECTRIC CHECK 220 VOLTS @PLUG MAKE SURE DOOR SWITCH IS FULLY ENGAGED
Nov 28, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
442 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
