Question about Delta Faucet Delta 156-WF Victorian Single Handle Kitchen Faucet with Matching Spray and...
Valve in Delta faucet closes as water warms up
I have two Delta faucets in the bathroom that have a problem with the valves closing, shutting off the flow of water. The faucets are three years old and the problem first surfaced in the hot water side but now seems to occur with the cold water side as well. When turning on the hot water, the flow would be normal, but as the water warmed up, it seemed the valve slipped closed, restricting the water flow to a trickle. It now seems to be occurring on the cold water side as well. It seems that some O rings or something have gotten worn out. Am I on the right track, and if so, how difficult is the repair?
  • 67 Answers
Yes, you are on the right track, but Deltas use a fancier kit inside them. It is quite a bit pricier than an O ring, but will solve the problem. It is not hard to install at all.
Posted on Jan 10, 2009
How do i fix my leaky moen bathroom faucet?
Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
Good Luck!
May 21, 2014 | Plumbing
Could my shower be airlocked
No, the ball valve is likely rotated 180 degrees from where it should be. Shut off supply and verify the hols in the stainless ball are facing to the same side as the seals are.
Or the supply valves to the shower are still shut off.
There is a small possibility the pressure balancing valve is stuck closed.
Jan 15, 2012 | Delta & Single Handle Shower Faucet
I have had my Delta bathroom faucet about four years. The hot water side drips. Can not get it to stop. It is one faucet with hot and cold handles with all sitting on a small platforum. The platforum is...
Go to delta website, take a picture of faucet with your cell phone and send. They should be able to identify and send you the parts. Meanwhile you'll have to turn water on and off from the emergency shut off valve under the sink. If it looks like the picture, it's probably the rubber seat and spring. If you don't want to wait go to your local "hardware" store. There may be someone there to help you. Bring the stem or cartridge, along with the rubber seat and spring. Don't use cold water while stem is removed. Turn cold off as well to prevent a mishap.
Apr 23, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
I have water hammer when using shower only
Your Delta faucet is open and close the valve very quick. This will produce back pressure on pipes. You need an anti water hammer / back pressure suppressor to avoid this problem. You can find it in local market.
Mar 30, 2011 | Delta Faucet Delta RP17453 Pull-Down...
To change my bathroom sink faucet I first tried to close the valves below. The cold water one shut just fine, but the hot water valve just won't move. I used a wrench to get leverage on it, but that didn't...
These shut-off valves don't last long before they lock up. There is always the chance that they'll break. Go ahead and turn off the main water valve, then remove the packing nut (Google images for valve packing nut). This should allow you to turn the valve stem. However, you still run the risk of not being able to get to shut off. I almost always have to replace these shut-off valves whenever replacing a faucet anyway. So, assuming the valves are threaded on to the supply pipe (not soldered) then buy replacement valves as a very first step. I am assuming you won't want to do the soldered fitting yourself. Good luck,
Jan 18, 2011 | American Standard Home
We have a Delta 172 single handle faucet. We had our hot water heater replaced. Now it takes longer for hot water to get to the faucet. Could debris (calcium build up, etc.) from the replacement get in...
Yes, debris from water heater replacements often breaks lose and gets stuck. The problem could potentially be anywhere between water heater and the faucet. The faucets shut off valves or the Delta faucet cartridge itself. Turn the hot and cold water valves off under the sink and disconnect the water supply lines from the faucet. aim the water supply lines into a bucket and turn the valves on one at a time. If there is a significant reduction in the water pressure and volume on the hot water side, you need to replace the shut off valve. If there is no reduction in water pressure, you need to clean and/or replace the Delta faucet cartridge. Contact Delta to receive free replacement parts.
Dec 11, 2010 | Delta Faucet Delta 172-SSWF Waterfall...
Shower/tub combo hot water problem
There is a restriction in the faucet or the piping to the faucet on the hot wtaer side...this will be very hard to find and fix... The shower uses less water so it will get hot.... the tub spout allows more water flow so you cannot get the water more then warm...
Take the faucet apart and blow out all the passage ways with air... also run some water from the piping while the guts are out of the faucet, to flush the piping...
Hopefully this will fix you up...
Mar 03, 2010 | Delta & Single Handle Shower Faucet
Bathroom sink pipes came apart and flooded our bathroom. cant find shut off valve to sink
Hi, W/D here.
Almost always, the shutoff valves are at the wall where water is supplied to the faucet. If the problem is with the drain piping, and the faucet valves don't leak, you don't have to shut off the water. Simply replace the drain piping and tighten it up. If you need any repair parts, you can get them from any hardware store. Please repost if there is anything else that I can help you with.
Good luck, and best regards,
Aug 13, 2009 | Delta Plumbing
How do I, myself, fix a faucet leak?
Faucets in general operate either with a one handle valve stem or valve stems that uses small pieces of rubber to precent the water flow. In a single handle model this is usually caused by mineral deposits building up and the valve not being able to fully restrict the flow of water. The fix here is usually a new stem. On models that use a two handle system and do have replaceable valve stems one must get a repacement seat from a hadware store and reinstall the stem. In extreme cases the valve body may need to be ground internally and will require a professional. If you do not a have replaceable stems than the only alternative is a new faucet. I hope this assists you and thanks for using Fix Ya.
Oct 29, 2008 | Plumbing
Delta Faucet Delta 156-WF Victorian Single Handle Kitchen Faucet with Matching Spray and... Logo
278 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
Level 1 Expert
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
