Question about Garden
Fuel mix ratio for Mitox 270MT - Garden
  • 104 Answers
SOURCE: fuel ratio for homelite ut10829
the ratio should be 25 to 1 so 250 mls of oil for 1 litre of petrol
Posted on May 23, 2009
  • 4088 Answers
SOURCE: gas ratio
Most saws built within the last 30 years or so can be run with 40:1 using modern synthetic saw oils. A number of late model units run 50:1. Make sure to premix the fuel and oil before adding to the saw. Hope this helps!
Posted on May 04, 2010
  • 4088 Answers
SOURCE: Fuel Ratio
40:1 is about right. Be sure to use modern synthetic oils made for saws and premix thoroughly before adding to the saw.
  • 221 Answers
SOURCE: what is the fuel mix ratio
50 to 1. try to find non ethanol fuel to run in it also.
Posted on May 17, 2010
heatman101
  • 43501 Answers
SOURCE: oil fuel mix ratio
The manual calls for 32:1 but they will also work well at 40:1
Posted on Feb 04, 2012
Testimonial: "Thank you Mr.Kolb for your answer. I kept telling my buddy to be sure about the oil ratio. I thought that trying 50:1 was risky not knowing for sure. He hasn't tried to do anything yet, now we have someplace to start. Thanks again"
Mitox 28lhr long hedge trimmer does not start properly. It takes at least 50 pulls of the start cord before it starts. I've changed the spark plug but to no avail. Any advice on how to help it start
  1. Switch machine to On position.
  2. Switch choke to full.
  3. Pump the primer bulb 5 or 6 times to prime the carb.
  4. Lock the throttle on with the throttle switch.
  5. Pull over until engine fires. (it may only be a quick pop)
  6. Switch to half choke.
  7. Pull over until engine starts and runs.
    Also check the air filter is clean and the fuel filter is good.
    I've added a link to the manual incase you didn't have it. Page 30.
    http://www.mowerspareparts.co.uk/v/Mitox%20manuals/271MT281MT.pdf
Apr 09, 2016 | Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
Fuel/oil mixture
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
From Poulan website:
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas. If you have other brands of equipment that require different fuel/oil ratios and you don't want to mix separate fuel cans, you should use the lowest numerical ratio. For example, if you have products requiring 40:1, 50:1, and 32:1 ratios you should use the 32:1 ratio for all products. This may cause slight smoke increase in the exhaust in the 40:1 and 50:1 products due to more oil in the fuel, but it won't damage either of the engines.
Aug 15, 2011 | Poulan Garden
Need to make 50:1 ratio mix. what i have on hand is the poulin 3.2 fluid ounce that makes 1 gallon at 40:1. how many ounces of this mix would need to be used to achieve the 50:1 mix ratio.
2 choices here
if you want to use the entire 3.2 oz bottle you need to add it to 1.25 gallons of fuel to = 50:1 ratio
if you have 1 gallon of fuel you need to add 2.6 oz of oil to the fuel to equal 50:1 ratio
hope that helps
Dec 28, 2010 | Poulan 2-Stroke Engine Oil - 24 Pack
What is the gas oil ratio of the ryobi leaf blower
Most Ryobi products made in the past 5 years use a 50:1 fuel mix. Check the fuel cap to see if it is listed there. The older Ryobi product used a 32: 1 fuel mix ratio and it was usually listed on the sticker that shows you how to work the choke. If in doubt, go with the 32:1 ratio. The only thing it will cause is premature fouling of the spark plug. Too little oil in the mix will cause premature engine wear.
50:1 is 2.6 ounces of 2 cycle mix to each gallon (U.S.) of gasoline.
32:1 is 4.0 ounces of 2 cycle mix per gallon.
I recommend to use a 2 cycle mix that is specifically designed for lawn equipment and contains fuel stabilizer. The ones with stabilizer will usually be .5 ounces larger.
Nov 30, 2010 | Ryobi Backpack Blower 25.4cc
What is the oil to gas mix ratio ?:? stihl fs 45
If memory serves, Stihl recommends a 50 to 1 mix ratio on the gas mixture...( 2.6 oz oil to 1 gal fuel ) I usually run mine just a smidge richer and run a mix of 45 to 1... ( 2.8 oz oil to 1 gal of fuel ) I also add about 1/2 oz of "Stabil" fuel stabilizer to the mix (holds down gumming of the fuel and keeps things running sweet)...hope this helps... ;-D
Aug 08, 2010 | Garden
What is the fuel mix ratio for a homelite chain saw 3300 14in.
May 15, 2010 | Garden
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Jul 05, 2009 | Yard Machines Garden
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
