Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-ez49 dvd recorder disc reads unsupported port
Disc is stuck in recording mode and will not return to play
Palmbeach
  • 185 Answers
SOURCE: DMR E55-P will not read DVD-R
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Posted on Mar 03, 2008
SOURCE: Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Posted on Apr 02, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
SOURCE: U88 displayed on dmr es15 panasonic dvd recorder.
Took off casing ,removed dvd unit. The laser runs along 2 metal spindles which i lightly oiled with wd 40. next to it runs another brass spindle which i also oiled. Re-assembled , and the machine is good as new.
Posted on Nov 16, 2009
How to play region 1 dvd's on dmr-ez27
http://service.us.panasonic.com/OPERMANPDF/DMREZ27-MUL.pdf
this plays region 1 or all regions disc.....recording format can be different, may not play some discs...read this.......good success, meder's tv service
Nov 28, 2012 | Panasonic DMREZ27 DVD Recorder
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Mar 08, 2009 | Panasonic DMR-ES10 DVD Recorder
Dmr ez25eb
clean the lense and try otherwise you have to replace the lense..
Aug 03, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
DVD recorder remote control wrong mode
I'm trying to record a DVD and get a message that says "Unsupport" or "protect". I did call Panasonic and they said it needs to be serviced. I just used it the othe day and I can't understand the failure. Whiel on the phone with the Tech support we did try three different + R discs: Imation, TDK and Sony. Can someone help me?
Jul 05, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Jan 15, 2008 | Panasonic (DMR-ES45VS)
Panasonic DMR-ES30V
I have three Panasonic DVD recorder/Vhs combos and I get the same problem from time to time...it may be the disks you are using.  Mine absolutely hate Sony disks.  I have the best luck with TDK or Maxell.  You also must clean your unit frequently, if you do alot of recording.  I use my units daily.
Hope this helps
Oct 31, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Dec 03, 2006 | Panasonic DMR-E50 DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
117 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
