Question about Ricoh Office Equipment & Supplies
Set up scanner on ricoh aficio 1515 - Ricoh Office Equipment & Supplies
NALDZ
  • 38 Answers
SOURCE: ricoh aficio 1515 all-in-one: problem with scanner
get your manual owner, and do the following instruction there
Posted on Jul 13, 2007
  • 65 Answers
SOURCE: printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Posted on Nov 25, 2008
SOURCE: Richo 1515 MF Error message: 12320 couldn't find the scanner.
The scanner had been previously configured and did work on another PC that crashed. We used adobe 5.0 to import. (obv this was awhile ago) I remember having this problem then but I don't remember how we fixed it.
It's a MF and the PC can print to it, but I can't get the scanner to communicate.
Any help appreciated.
Posted on Feb 27, 2009
SOURCE: How to set up my Ricoh Aficio 1027 to be a scanner?
NECESITO QUE POR ESPAñOL ME FACILITEN LAS INSTRUCCIONES DE COMO MANEJAR ESTA FOTOCOPIADORA
Posted on Jul 11, 2009
Ickoajnc
  • 183 Answers
SOURCE: My Ricoh Laser Printer is not working
For to use the network printer first of all you should have a network connection port.
If you have one on your printer than you should install a driver on the computer from where you will print then connect the cable with network LAN cable which the one end is connected into the printer and the other into the network switch or router. After this is done go to start menu on you computer than go to printers and faxes and select the printer driver 1515 press the right click and click on properties then go to port and create a TCP/IP port similar to the computer ip address.
EXAMPLE:
if the address on the computer is 192.168.0.100
than put the address of the printer as follow
192.168.0.101
Please look at the paper sheet which is printed from the machine by her self when the machine is turned on for the first time in the day.
There should have a port name which can be 10001 or 9100 or 9101 or similar.
Enter that number in the TCP/IP port properties than go to the machine and press the [User tools/ Counter] key then go to system settings and than network settings and enter there the ip address which you had enter before on the driver in the computer.
Posted on Jul 16, 2009
WHAT RICOH PRINTER IS COMPATABLE TO THE RICOH AFRICIO 1515
The 1515 is compatible to the 161 and the 171, the two newer generations of similar printers. All three use the same toner and photoconductor units, and are set up almost identically.
Nov 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I have a Ricoh Aficio 1515 MF. I cannot get my Windows XP Pro to recognize the scanner, and I downloaded the Twain driver from the Ricoh site. Help! I want to scan into Adobe Acrobat.
Does the machine show up on your computer - you can print?
do you see it in scanners and cameras in start - control panel -> scanners and cameras? what is the status shown there on the properties?
Jul 30, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Needed to have machine reset and now I lost my scanner
Do a Google-search for "Ricoh Aficio 1515 Printer downloads".
Select and download and install the software-drivers for your printer.
Jul 22, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh 1515 scanning direct to emails
you will need the copier hooked to a network and able to get out to the internet. You will need a email account like comcast.mail.net and password if your mail server has authetication. On the ricoh go to USER TOOLS buttom choose SYSTEM SETTINGS - FILE TRANSFER-SMTP and enter the setting there good luck
Jun 27, 2008 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio 1515
On the left inner corner has a white female connector for it
May 23, 2008 | Ricoh Aficio 1515 All-In-One Laser Printer
Printer Ricoh Aficio 1515
delete drivers and reload, make sure you're using PCL 5 drivers.
Aug 14, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh aficio 1515 all-in-one: problem with scanner
May 03, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
