Question about Kitchen Ranges
Tappan gas range oven door hinge is binding
The oven door opens and closes, but the right hand hinge binds or makes a loud popping noise whenever the door is opened or closed.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 30, 2012
SOURCE: MAYTAG (AMANA) OVEN DOOR
I finally got my door back on, I had to wedge a butter knife in the hinge to keep it open, then I could put it back on the pins and slide the metal cover/locking thinge over it. Was a pain in the ass.
DANGdoor
Posted on Dec 02, 2007
jumptrout51
  • 3361 Answers
SOURCE: Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
Posted on May 05, 2009
  • 7 Answers
SOURCE: DCS 30 inch oven door fell off
please contact me at verng@craneengineering.com for a solution to this problem.
Posted on Nov 06, 2009
heatman101
  • 43501 Answers
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
TheMobilian
  • 8220 Answers
SOURCE: Viking Range Oven door will
Viking duel fuel service manual
See page 38
Posted on Sep 17, 2010
Add tension to loose oven door amana gas model args7650ss
Hello. You will need to replace the door hinge assemblies. The part numbers are as follows:
Right hand hinge 31715202
Left hand hinge 31715201
I hope this helps you.
Aug 14, 2015 | Amana Kitchen Ranges
Liftmaster GDO goes up 1/2 way and stops,springs are fine.
The Liftmaster openers have 4 movement switches, a )opening and b) closing limit and c) opening and d) closing force. First check the door for smooth operation by opening the door by hand (disconnect from the opener with the release cord). Any binding should be felt this way. It is possible for a binding hinge, roller or torsion springs to add too much drag and cause the force switch to shut off the motor. Hinges, roller shafts and torsion springs should be lubricated at least annually with a non oily spray (silicone or teflon spray). Not WD-40 or 3-in-1! A light band of lube should be applied to the torsion spring coils. If the door can be operated smoothly by hand, then adjust the closing force switch 1/4 turn at a time. This is a safety device do not use it to overcome another problem!
Aug 15, 2014 | liftmaster Garage Door 1/2 Hp
How do I get my kelvinator stove's P 12 front door back
Without more information I can't be sure of your problem but I will make a guess that you removed the door without engaging the hinge locks. I am attaching a video that may help. All oven door hinges are not the same. Some require you to insert a screwdriver or pin in a hole to stop the hinge from retracting. My own oven door has retainers that snap onto the slot just above the hinge. When you remove the door these pieces are used to hold the hinge in the open position.
If the hinges are in the closed position you will have to figure out how to open them and hold them in the open position. Be Careful. The springs are very strong and can hurt you. I am including a link to a youtube video that may be the same as your oven door.
This free troubleshooting video shows step-by-step instructions on replacing the oven door hinge on Frigidaire, Electrolux, Gibson, Kelvinator, Tappan, and Kenmore gas ranges.
Door Hinge Replacement part 316456302 Frigidaire Gas Range Repair
Aug 15, 2014 | Kitchen Ranges
Oven door will not close all the way. 6" gap at the top. No problems until last use and now won't close. Any hints on how to proceed would be appreciated. Thank you!
Most oven doors are held in place by two hinges at the bottom. Usually these hinges are not attached but hook into the oven.
Sounds like you need to readjust one or both of the hinges.
Usually can be done by pulling up on the door and pushing the bottom of the door in.
Write back if you have more problems.
Dec 02, 2009 | Tappan TGF320 Gas Kitchen Range
Oven door
replaced oven igniter without removing oven door
Jan 08, 2009 | Tappan TGF657 Gas Kitchen Range
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Jun 10, 2008 | Tappan TGF320 Gas Kitchen Range
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchen Ranges Logo
109 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
