Question about Brother MFC 7420 All-In-One Laser Printer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
    Problem Solver:
  • 11 Answers
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Posted on Jan 09, 2013
  • Christine Fernandes Nov 24, 2015
    i have done the above process several times and still doing it
prashanthcl
  • 460 Answers
SOURCE: black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Posted on Aug 22, 2009
Testimonial: "This has been extremely helpful .. many thanks"
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
  • 133 Answers
SOURCE: Brother MFC 7420: After changing the toner
Just need to clean up all glasses with alcohol and move the blue panel to clean the drum, after that sould be fine.
Posted on May 22, 2009
  • 7 Answers
SOURCE: Wrong ink in slot
POWER PURGE!!
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Posted on May 11, 2011
  • 411 Answers
SOURCE: We have a Brother MFC 7420. Printing now give long
That's usually a bad cartridge, but can be from the wire not being cleaned by the slider, or a worn drum. If it's close to time for the drum to be replaced, I'd start there. The number of pages between drum changes is not a hard rule, but a generality. Drum wear depends on paper used, humidity, OEM or remanned cartridges, total page coverage, etc...
Posted on Jul 05, 2011
My brother mfc-7420 will print but won't let me scan and i can not find my disk
Go to the Brother web site and put in your MFC info and you may download it for free. If you find it to be difficult you may call Brother for support and they will walk you through it. Do not have to be under warranty. Hope this help you out.
Aug 28, 2012 | Brother MFC 7420 All-In-One Laser Printer
When i am faxing do i put the paper up or down on this thing brother mfc-7420
Either lift the lid lay the paper in print side down, or put it into the document feeder print side up. In either case the top edge of the page should be at your left to appear right-side up at the receiving, but that's a minor point.
Sep 15, 2010 | Brother MFC 7420 All-In-One Laser Printer
Black line 1cm in from margin when printing
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Mfc-7420 Black Line horizontal across paper in 3 places
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
842 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
