Question about Health & Beauty
Rascal mobility scooter 329 le/ brake keeps snapping on on downhill run
Auto brake come on every few yard on a downhill run / it runs perfectly on the level and when climbing. I have fitted new batteries. But it made no difference / I would be great full for any advice ect
  • 1,271 Answers
Deos the brake click when this happens ? now if that's the case that is the controller not supply a voltage to the break otherwords it being released, now discoonect the brake and measure the resistance , it should be about 50ohms , ifit's too low that could cause a problem,
Posted on Dec 09, 2012
5 Suggested Answers
gewiz
  • 1271 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
wcdoc1953
  • 280 Answers
SOURCE: please find users manual for Rascal 329 LE
The following link may be helpful for the users manual for your rascal scooter:
http://www.rascalscooters.com/manuals/300_manual.pdf
You can also call the manufacturer and they will send you one. The manufacturer is
Electric mobility at 1-800-MOBILITY or 800-662-4548. Hope this helps.
Posted on Nov 23, 2010
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
SOURCE: I have a rascal mobility scooter, TE 388EMI have
Hello, i work for Electric Mobilityand we manufacture that model of scooter. If you call 0800 252614 you can speak to a member of the customer service team who can help. Different bleeps mean different things. Alternatively, you can take the scooter to your local retailer to be serviced - call our customer service department on the number and they will be able to point you in the direction of your nearest stockists. Hope that helps.
Posted on Jul 03, 2011
Red lite flashes when i plug it in
I can only guess that the batteries need replaced .
Sep 05, 2015 | Rascal Auto Go 550 Portable Power Scooter...
What is problem with my rascal 305 four wheel scooter
your problem is related to the overload breaker on the chair you need to figure out why the breaker is tripping either due to batteries going bad or the brushes in the motor need adjusting or replaced , also you need to check the automatic brake is releasing completly a dragging brake will cause the auto reset breaker to trip
Oct 01, 2014 | Health & Beauty
Does anyone have arepair manual for a rascal 300 I need to fix the electromagnetic brake
It is the same as a Rascal 600 only the 300 has smaller wheels.
The manual is not much help on the brake, it does not go into repairing the bake, except for checking voltages and replacing the microswitch, some tips are a little oil on the detent balls help to keep it free and movable, but don't get oil on the brake pad.
Scooter Doctor App
Aug 27, 2014 | Rascal 300 Electric Scooter - Used...
Rascal scooter 245
Most of these chairs have a clutch release lever near the motors. Move it into free-wheeling and it should roll nicely.
Aug 23, 2014 | Electric Mobility Invacare Pronto M41...
My dads mobility scooter wont go and the two light on the black box under the seat are not on .
A blown charging circuit fuse? The fuse may be under a floor hatch and mat and not feature in the manual - that turned out to be the case with a Pride Mobility scooter.
Jun 03, 2014 | Pride Health & Beauty
I have a puncture on my front wheel tyre on a rascal 302 le how do i get it off
Remove the axle and drop off the tire. Tools needed are a 5mm and 6 mm Allen wrench
Feb 10, 2014 | Electric Mobility Shoprider Electric Power...
How to make rascal 600 scooter fsater 5 mp.
in order to get it to go faster, you could put larger wheels on it, or get an OEM programmer to adjust the speed. They did not want to be sued so they did not make them available. any of the higher speed scooters have hand brakes. There probably is a market to sell ways to speed up Rascals, but I can not except the liability. sorry Scooter Doctor App
Feb 12, 2013 | Electric Mobility Rascal Scooter...
Please find users manual for Rascal 329 LE disabled scooter
Nov 22, 2010 | Electric Health & Beauty
Electric mobility Rascal 265 LE scooter won't run 24 volts dc on batteries no sound or movement
May 02, 2009 | Electric Mobility Mobility Electric Power...
I AM ONLY GETTING 9.3 VOLT TO THE MOTOR
Just to be sure have the batteries tested with a load tester. Then ohm test the brake. It should be around 35 ohms.
Dec 21, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
150 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
