Question about Kitchen Ranges
Burner will not shut off
When turning on front large burner - jumped to high heat - then would not shut off - had to turn off breaker - remove knob - needs fixed - any solutions
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 30, 2012
  • 58 Answers
SOURCE: GE Spectra Profile - dual burner only has one temperature - HIGH!
you need a new switch that is in the control panel
Posted on Mar 12, 2008
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
SOURCE: Front burner won't shut off. Have to close at breaker.
For $9.99 I will be glad to share the solution.
Posted on Jun 21, 2009
One of the burners on my Maytag "Cernan" cooktop will NOT turn off. I had to shut the breaker off. How can I disable that one unit?
The switch or knob for that burner is shot. to disconnect that burner first see if there is a fuse that goes to just that burner and take it out. That should stop any power to that burner. If not take the knob out and undo the wires to that switch and put electrical mar rets on the wire ends. Just as a precaution put electrical black tape on the outside of the mar rets to make sure they do not come off. DO NOT try to put these wires back on the switch.
Sep 18, 2017 | Maytag Heating & Cooling
Both front burners won't turn off.
Replace the switches for burners that are not turning off.
Sep 05, 2017 | Kitchen Ranges
Large left side, front burner, does not shut off when you turn the control knob to, OFF. It gets very very hot and remains that way for a long period of time. I can keep turning the , OFF, knob, but...
That means the switch is shorted(the contacts welded their self together) the only fix for that is to replace switch. AS A SAFETY PRECAUTION UNTIL THE SWITCH CAN BE REPLACED TURN OFF CURCUIT BREAKER TO STOVE
Gene
Aug 01, 2011 | Kenmore 95313 Stainless Steel Electric...
Hi I have an xl80 the burner lite and heats up till at desired temp, after burner goes out the fan keeps on running 15 minutes or so. If I go down and shut off power switch to furnace then the fan shuts...
Hi, sounds like you have a problem with the heat anticipator in the thermostat. If you replaced the fan limit, and with it running that long after the burners shut down, it would be in your stat. If it fires up after resetting breaker, was the stat set to call for heat? If not, the stat is faulty. If you remove the front to get to the stat wires, take a jumper wire and jump from RH or RC to W. Heat will start. Let it run for a minute or so and remove wire. If the fan shuts down with in a min. or so, you will know it was the stat. Good Luck and let me know the out come!
Shastalaker7
A/C, & Heating Contractor
Feb 11, 2011 | Heating & Cooling
Tappan ES 200 burner stays on high and not turning off.
I need to clarify a bit.... did you remove the knob and check where the metal rod inserts into the plastic knob hole? If that is chipped on the inside, it will not turn the metal rod that comes out of the stove. Take the knob off, and use a pliers to turn the metal rod. Leave me comment if you have already checked that or you do not have that type of knob on your model.
Nov 17, 2009 | Tappan TGF320 Gas Kitchen Range
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
