Question about Jensen Vm9311, Vm9311ts, Uv7, Uv7i Fpc Ribbon Cable For Screen
Says sreen standby touch screen to resume. nothing happens
Touch screen not working
Touch screen is not repairable only change
change your touch screen then use your machine
Feb 14, 2014 | Minolta bizhub 350 Black and White Copier
Pioneer DVD player DV-220v-K not responding to Open Drawer command
This is a mechanical problem and will only get worse, caused by gear ware timing issues, or jamming.
Apr 19, 2012 | Pioneer Televison & Video
Hi, our aspire 1 netbook (AOA150) constantly says resuming winows when turning on but nothing happens. i've tried pressing F8 as sreen promts me to but nothing? i have also tried recovering the...
Hello akashket,
Welcome, and thank you for using FixYa!
Here is your solution. Unplug the power to this laptop, and pull the battery out. now let the system sit for 10 minutes with no power source to it.
After 10 minutes, replace the battery and then the power cord. Boot the system up. It should shoot right in to Windows now.
Have a great day!
Sep 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
Lap top shows a screen saying "Computer is locked" just clicking on the box, makes it go to the next screen. just a hasle doing this every time.
In order to remove the lock screen after resuming from screen saver, sleep, standby, and hibernate, please follow these steps.
Windows Vista/7
1. Right click on an empty space on the desktop and select "Personalize"
2. On the far right of the Personalization window is the option for Screen Saver. Click "Screen Saver".
3. Unselect "On resume, display logon screen".
4. Click "Change Power Settings".
5. Click "Require a password on wakeup" on the left hand pane.
6. Select "Don't require a password" and select Save changes.
Windows XP
1. Right click on an empty space on the desktop and select "Properties"
2. Select the Screen Saver tab.
3. Unselect "On resume, display Welcome screen" or "On resume, password protect".
4. Select "Power".
5. Select the "Advanced" tab.
6. Uncheck "Prompt for password when computer resumes from standby". Click Apply, then OK, and then OK again.
Good luck, please post back if you have any difficulties, and thanks for using FixYa.
Apr 11, 2011 | Computers & Internet
Monitor picture fades out.
I thought my problem was originally monitor related. However since I posted, the picture disappeared altogether, and my PC wouldn't even start to bootup. Fearing my mobo may have died I removed the hardware components, cleaned then re-assembled them. After all that, it turned out that my graphics card has a tendency to become slightly unseated. Once I was aware of this problem booting up resumed normally. It seems that the problem of the fading monitor picture seems to still occur, but soon after I use the machine after 'hibernation' state, and even then it doesn't always occur if I do use hibernation. I haven't used hibernation for a little while and so far the problem has not returned
Mar 28, 2009 | NEC Mitsubishi Diamond Pro 920 19" CRT...
Swap nintendo ds screens
No the top is just display while the bottom is a touch screen. Two types of screens physically impossible to switch.
Mar 15, 2009 | Nintendo DS Console
Daewoo 42
i wiuld guess that the power supply failed. thats the perfect discription of how it happens. find the board and install it. it should be easy.
Jan 20, 2008 | Televison & Video
Cracked screen
hi, can someone help me and tell me where i can buy a new touch screen. thanks...
Jan 08, 2008 | O2 Xda Atom Exec Smartphone
Jensen Vm9311, Vm9311ts, Uv7, Uv7i Fpc Ribbon Cable For Screen Logo
19 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
