Question about Panasonic DMR-ES40VS VHS / DVD Recorder Silver
Panasonic DMR-ES40V Self Check displays Code F60 then a blinking Clock then displays Code F04 I don't know that the codes mean.or how to do I Fix the Problems?
I have already tried removing plug. wait minute then plug in again when the self check starts Held down the power button until i got the blinking clock. if i then hit the DVD Eject/open button the Display showed HELLO but nothing is working. I Pulled plug when restared up again when I got the blinking clock let blink but the display went to code F04 within a minute. I could never get a image to display on the tv screen to use setup. The ON/OFF Button dont work.
SOURCE: DMR E100H panel button does not work
call Panaonic 1 708 981 4842 and talk to tech support, it sounds like a faulty unit and should be return immediately
Posted on Feb 08, 2008
Palmbeach
  • 185 Answers
SOURCE: Power on, makes the LED goes off
Hi
Yes, it is definitely worth fixing!
The problem you will have is getting someone to do it for a reasonable price. I can tell you how to repair it but you will need to find someone who can use a soldering iron or have a go yourself. If you haven't used a soldering iron before, it's not a skill that can be picked up over night. A bit like riding a bike, it seems impossible until you can do it.
The fault has almost certainly been caused by a faulty component on the power board. It's an easy repair but you will need to dismantle the unit to get to the board. It's not difficult. You can get a new component online for a few pounds/dollars.
Nikko Electronics will supply the component or there are other suppliers.
I have given full instructions >HERE< to repair the DMR E55. The E85 is not exactly the same, but its very similar and it will be the same component.
Hope this helps
Posted on Jun 12, 2008
  • 309 Answers
SOURCE: Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Posted on Nov 20, 2009
SOURCE: Panasonic DMR-ES46V shows F60 Error
I have same problem with es40v - f60 error with no response to troubleshooting protocol. This machine also was used very little & also has a history of turning itself on. Panasonic used to make high quality products. A shame that their products are no longer trustworthy. I can understand that machines break - i'm very frustrated to learn replacement parts are not available. Guess i need to re- think brand loyalty.
Posted on Feb 12, 2010
SOURCE: Panasonic DMR-EH50 Keeps self-checking. Will not eject disk.
replace caps in power supply and strg6353 ic
Posted on Mar 12, 2010
Panasonic dmr-es40v
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
Jul 08, 2016 | Panasonic DMR-ES40VS DVD Recorder/VCR
F60 displays on Panasonic DMR ES40V and efforts to reset unit have failed.
I had the same unit and had the same problem occur.
Finally contacted Panasonic service and sent it for repair.
They replaced it w/ a refurbished model.
http://www.service-center-locator.com/panasonic/panasonic-service-center.htm
Jan 21, 2015 | Panasonic Televison & Video
I have panasonic dmr-ez485v dvd recorder cambo, it has F60 code don't turn on or off
Hit reset button, unplug it or swear at it. If you looked up online find more problems listed on unit then ways to correct problems. Does have nice play back. I bought a DVD maintenance kit seams to help some issues. good luvk
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
F60 ERROR CODE ON PANASONIC DMR-ES40V
Unplug the unit for 24-hours. I know, it should not take that long, but in this case I tried shorter periods WITHOUT success!
Just before plugging in unit depress and hold POWER button. You are supposed to hold it for 30-seconds after plugging in, but in my case I did it for 60-seconds. This results in a MASTER RESET that clears all errors, resets interlocks, etc. I could not get past a DVD failure problem, but when I discovered this process everything worked fine!!
Good luck! Hope it works for you too.
Jul 17, 2010 | Panasonic DMR-E85H DVD Recorder
DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Sep 02, 2007 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic DMR-ES40VS VHS / DVD Recorder Silver Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
