Question about Kyocera CS-2550 Black and White Copier
Cs-2550 ISERIES network printer
Copier does not print Iseries output, prints othet network data, copies, etc but Iseries data does not print and does not activate the device.
keithd2704
  • 56 Answers
SOURCE: CS 2550 software
You can find the drivers for this unit at the Kyocera-Mita America website. Follow this link to the download section and find the appropriate drivers for your operating system. I would suggest using the KX Drivers as they are the most useful and offer the greatest control of the printer.
http://www.kyoceramita.com/download/
Choose your country and then find your model of system. You will see everything listed at KM series, these are the same devices just labeled as CS for the Copystar line of machines. Find the KM 2550 driver file and download the software and install it as you would any other printer in Window or Mac OS.
I was a Systems and Technical Sales Engineer for Kyocera-Mita for more than 6 years from 1998 - 2005 and worked extensively with the R&D Teams in Japan on the development of these systems.
Hope this gets you going.
Cheers,
Keith
Posted on Dec 07, 2008
  • 66 Answers
SOURCE: Copystar cd-2550 copier , drum replacment print problems
hi
the drum unit on this model has two plugs which need to be plugged in and one on the dev unit that can come loose.
also the metal mechanism under the dev unit has to be pushed in to enable toner to get onto the drum.
is the transfer roller fitted correctly?
Posted on Apr 23, 2009
SOURCE: Cannot print to network printer
Is this printer installed on a server and shared over a network? Or is it installed independently on each workstation?
If it's on a server, printing could be "paused", or set to "use offline" Go to the "printers and Faxes" dialog box, and 'right click" on the printer icon, is there an option to either "resume printing", or "use printer ON line"? If so, select this option.
If it's not on a server then it would be extremely unlikely that this condition would happen on all workstations
Other than that make sure that the Subnet mask is set correctly on the printer.
If that doesn't work....it's probably time to try re-installing the driver.
Posted on May 16, 2009
Gort007
  • 1187 Answers
SOURCE: how to print 11 X 17 documents using a Kyocere CS 2550 printer
Use this method:
[File]
[Print]
Select the printer from the list and click on [Properties]
Change the "Original siae" to "11x17"
Change the Output size from "Same..." to "8.5x11" or "8.5x14"
[OK]
[OK]
Posted on Sep 29, 2009
  • 158 Answers
SOURCE: When I print multiple copies from a networked
when you click on file then print look in bottom right corner and you will see a box that says collate uncheck that box and it should staple correctly for you
Posted on Oct 03, 2009
Testimonial: "It worked! So simple! Thanks!"
I am using LabelView to create a label that will be imported into an iSeries system. I am using Zebra 140xiIII as the printer in LabelView. When I import this label file into the iSeries system, I am...
iseries uses EBCDIC and the file is probably ASCII when importing from/to the iSeries charset convertions ensues, there must be some char that isn't translating well and thus converting itself in some control code, use DSPF or EDTF to open the file and check with F15 the encoding for more info I need to know what is your system CCSID
Apr 28, 2011 | Zebra 140XiIII Plus Thermal Label Printer
The copier keeps printing the same document. There is nothing on the computer that is spooled. How do I stop the printing and clear it out?
Try this... Remove all the connection to the PC (USB, network or parallel). Turn off the printer on the power plug for about 3-5 minutes. This will clear all the documents sent previously.
Mar 09, 2011 | Kyocera CS-2550 Black and White Copier
Blank copy
please check corona wire may be it was broken re-wear it then print ok
Nov 21, 2009 | Kyocera CS-2550 Black and White Copier
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
How to print 11 X 17 documents using a Kyocere CS 2550 printer
Use this method:
[File]
[Print]
[OK]
[OK]
Sep 29, 2009 | Kyocera CS-2550 Black and White Copier
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • BOOTP
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Jul 28, 2009 | D-Link DP 301P (DP-301P) Print Server
Printing problems (InfoPrint 6500/iseries)
need more info plesae give me the most information on type of equipment and software issues and driver setting if you know and version of software may be helpful infor mation
contact threw this web site
rod the candymangandy
Feb 03, 2009 | IBM Infoprint 6500 Matrix Printer
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Kyocera CS-2550 Black and White Copier Logo
35 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
