Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Problem with Bissell 7901-1 my red lint filter fell into the body, how do I get in out?
Shook machine upside down - still in there.
  • Leon Nov 30, 2012
    Yes - the service manuel will be a big help- THANKS!
  • Leon Nov 30, 2012
    Now, if I could only find my screw driver?
  • Bissell Master
  • 18,424 Answers
  • 48 Answers
SOURCE: connecting a BISSELL AUTO MIX PISTON TO A AUTO MIX KNOB
Take of the housing ,turn it over and you will see the under side of the auto mix dial , Then turn the auto mix dial to rinse only;
On the top of the piston you will see a small slot , this fits into
the out side spiral on the auto mix knob with the dial set to rinse only the top part of the spiail sould point to the courner
Tilt the piston slightly,then hook it on the point of the auto mix knob , when you turn the auto mix dial to heavy traffic the piston should slide down the outer spiral of the auto mix-dial ,
Put the housing back on with the auto mix dial set to heavy traffic, but make sure no tubes are trapped or this will stop the flow of water,
i hope you can under stand what i have wrote ,Goodluck
Posted on Nov 29, 2007
reddevil6
  • 1673 Answers
SOURCE: Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
Posted on May 26, 2008
  • 272 Answers
SOURCE: Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
The 7920 is a 220 volt version of the 7901. I found a shop in New Zealand of all places that has service manuals on line. They are sort of picture books, but using them has saved me a lot of money as it makes repairing much easier. Here's the link you'll need. Good luck. If you need any more help, just add a comment to your post and it will go to my e-mail and let me know. The heads you clean are just the outlet spray heads when they get gunky.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Looks like you already have the USELESS Bissell advice list!
Posted on Jun 03, 2009
  • 10 Answers
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!!
Posted on Sep 26, 2009
VacuumRepair
  • 438 Answers
SOURCE: Bissell Proheat model 7901-1 is there diagram of
I have pasted a link to the Bissell ProHeat series carpet extractor repair guide below. This guide is like my Bible when I'm working on these machines, and is EXTREMELY helpful on explaining how, and where hoses and parts go, and possible explanations of problems, and how to fix them.
I hope that this information is helpful to you, it sure is to me. If you did find this helpful, please be so kind and vote my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is what really keeps repair professionals like myself keep coming back and giving free repair advice, we greatly appreciate when people acknowledge our work here. Thank you ahead of time.
Bissell ProHeat Repair Manual
Thank you again,
Chris J.
GoVacuum.com
Posted on Apr 15, 2010
How to assemble Model 7901-T. My wife has bought a Bissell Proheat Plus Model 7901-T. She has lost the manual for me to put it together. Is there an online manual for the assembly of this machine?
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Can any one send me a diagram of the internal water and soap connection for A Bissell proheat carpet cleaner Model #7901-1. i imagine pump also needs to be primed, which port do I use to do this. Thank you...
Click here for the manual - We think this will guide you,
As for the pump / port to be primed -
For Prime and loss of prime please click HERE -
From what Bissell says you must prime both - please read page 7 especially.
This should get you good to go.
Gary
Apr 10, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Need to replace red clips that hold rolling brush on 7901 Proheat
On the bottom of the machine, near the belt access area,
is a red retainer plate that holds the black brush arm and
brush in place. Using a Phillips head screwdriver remove the
screw that holds the red retainer plate in place. p/n 5559113
Jul 12, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Jun 03, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
the water head are pluged use a tooth brush and some hot hot water and brush it on the tips until they are unpluged
May 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat
Take it outside, upside down and have a good look at the brush area. I use a garden hose to clean it after every use.
Aug 23, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
127 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
