Question about HP (REFURB) HP XW8000 XPP X 2.6GHZ 2P 36GB SCSI 2GB DVD CDRW NVS280 RMKT HP (C39951999BGSP) PC Desktop
Xw8000 beeps When I boot up the screen is dark and I receive a series of one long beep and two short ones. It sounds like memory. I had best buy replace the MB due to a bad board. It has not worked since. It booted up once after I got it home. Best buy will crucify me if I allow them to work on it. The MB is fine...could it be the ram is bad?
    President:
  • 1,179 Answers
This code is either for improperly seated or bad RAM or improperly seated or bad video card. Try reseating these parts before spending $$ for replacements as it might just be they aren't fully seated in the slots. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 10, 2009
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
AMD sempron power supply
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Computers & Internet
One beep, quick pause, then constant series of beeps. Memory, cpu, power supply replaced. Shows the Asus boot P4B533 graphic on screen while error beeps. I get the proper related error beeps if memory, agp...
It does sound like the motherboard failing as you have tried everything possible. Could be the bios chip corrupted.
As to a replacement, Ebay is your best bet, as there do not be any suppliers offering this older board now
Jan 15, 2011 | ASUS P4B533-E (P4B533-E/L/1394)...
Powers on for 5-6seconds then beeps one time and shuts down
Here are the beep codes for common BIOS programs:
1 BeepA single beep from an AMI based BIOS means there has been a memory refresh timer error. The solution is often to replace the RAM in the computer.
A long beep from AWARD is probably memory error.
1 short beep from AWARD bios & PhoenixBIOS and most others is a positive ok signal.
Without more information, it sounds like it is a memory problem. Remove the memory and see if it will boot to the BIOS/setup screen. If so and you have multiple memory sticks, put one in and try to boot. If that fails try the other.
Aug 20, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
On power up it beeps 3 to 4 times and won't boot up
If there is no display coming on your screen check your computer RAM here is the beep codes for your dell computer i hope this will work for you
Regards
manish
Mar 24, 2010 | Dell Inspiron 530 Desktop Computer...
4 short beeps
4 short beeps indicates memory problems. Either the RAM modules are incompatible or they are faulty.
Are you trying to increase the total RAM if so use the same modules from the original manufacturer but larger capacity but the same speed.
Sep 14, 2009 | EliteGroup K7VMM Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Acer Aspire 3 Beeps, No Screen
you will have to find what the beeps mean could be faulty memory or other hard ware problem try removing some memory or using other memory to eliminate memory problems or change video card
Jul 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computer will not boot
3 beeps = memory
long beeps = processor
long and short mixed = main board,,,
yours sound like memory, try the memory in another pc and see if it works
if it does its your processor
cheers
Jan 05, 2008 | AOpen AX34-U Motherboard
HP (REFURB) HP XW8000 XPP X 2.6GHZ 2P 36GB SCSI 2GB DVD CDRW NVS280 RMKT HP (C39951999BGSP) PC Desktop Logo
196 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
