Question about IBM System x3400 M3 7379 Server tower 5U 2way 1 x Xeon E5506 213 GHz RAM 12 GB SAS
Ibm server system x 3400 ornage light meaning
paand
  • 147 Answers
SOURCE: raid 1
there must be some key on the startup to enter into the raid menu. And in that raid menu you can create raid .
Posted on Jun 23, 2009
JAIN_IT
  • 73 Answers
SOURCE: when iam try to install windows 2003 server in ibm
Please chack your cable connections .
http://webcache.googleusercontent.com/search?q=cache:wVeOJoYR170J:www.techspot.com/vb/topic127298.html+no+hard+disk+drive+detected+in+the+server&cd=3&hl=en&ct=clnk&gl=in
try this link.
JAIN_IT {INDIA}
Posted on Sep 18, 2010
  • 143 Answers
SOURCE: i want to see how
Welcome to Fixya
Please do the following to replace the ram
1: Open the side cover of the server using the key provided by IBM. 2: Remove the SMPS ( Remove both if contains) 3: Then Open the power cage ( cage where smps is inserted) using the lid 4: Now you can see the memory area and replace the ram
Thanks
Posted on Mar 05, 2011
  • 143 Answers
SOURCE: SERVER IBM SYSTEM X3400: "CONTROLLER MONITOR
Welcome to fixya
This error can come if there is any issue on Raid controller
Most probably , dust will be the enemy.
Just re-fix the raid controller and check. ( Power off the server while doing this job)
After re-fix check if it works . If it doesn't then it's time to replace the controller.
Thanks
Vote me if it helps you
Posted on Mar 22, 2011
  • 143 Answers
SOURCE: exclamatory mark led glowing in amber on the
Welcome to fixya
Amber led glows when server met with hardware issue. You will have to run the IBM DSA tool inorder to find the hardware that has issue.
Thanks
Posted on May 03, 2011
Ibm server 3400, error controller monitor
remove the adaptec and see whether you can get a normal boot. this could be caused by either a bad 2405 or bad riser card.
on X9 series SM board, to enter BIOS setup, you must hit F11, then select "setup" instead of the usual "del" key.
Apr 02, 2014 | IBM Computers & Internet
Server ON only by pressing power on button continously otherwise server downs & no display
where the cable for the power sw connects to the motherboard your polarity might be reveresed. Therefore, try switching the plug-in the other direction (groung and colored wires).
Sep 18, 2012 | IBM eServer xSeries? 3400
While i am tring to repair 2003 standard server on IBM 3400 Tower server i am facing a issue that hdd not found
Windows not see the disk because they are connected through a raid controller.
When you start the recovery windows you have to offer the installer the driver for raid. Installer wait new driver only 5 seconds.
During this time you must press "F3" and point driver on floppy.
Jun 16, 2011 | IBM x3400 Server
Hi I have an IBM 3400 server running 2008 sbs 64X. All I want is to monitor the raid controllers so that I can see if all is working as it should. I know the software is on the original disks but...
Welcome to fix ya
Yes you can monitor the raid controller by using IBM RAID MANAGER softwfare. Hope you are having windows platform . Click the below link and download the software.
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-61707
please download the file named ibm_sw_srapp_9.20-16999_anyos_32-64.iso . After download burn it into cd . Now insert the cd and install the raid manager software.
Thanks
Please vote me if you are satisfied with my answer
Apr 06, 2011 | IBM x3400 Server
X 3400 drivers for seven
put reboot disc in it will give you all your drivers back in system.
Feb 14, 2011 | IBM x3400 Server
I want to see how to replace ram from ibm x 3400 server.i mean how to pull the covers of tower model so that i can rech to ram
Welcome to Fixya
Thanks
Dec 13, 2010 | IBM x3400 Server
Exclamatory mark led glowing in amber on the front panel It is IBM server 3400
Welcome to fixya
Thanks
Nov 16, 2010 | IBM x3400 Server
Raid 1
Jun 23, 2009 | IBM x3400 Server
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
IBM System x3400 M3 7379 Server tower 5U 2way 1 x Xeon E5506 213 GHz RAM 12 GB SAS Logo
27 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
