I press bottom tv clicks on them goes back off
I here a clicking sound coming from the back
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Power relay is coming on then going off--what ever brand or model it is a power supply problem.
Posted on Dec 22, 2012
  • 1153 Answers
SOURCE: MITSUBISHI TV STOPPED WORKING
If you can do self test diagnosis, read threads here on Mits, or goto ctechnicians.com
Posted on Dec 16, 2007
  • 7 Answers
SOURCE: Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Posted on Nov 14, 2008
ginko
  • 19396 Answers
SOURCE: Clicking sound!
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
Spencerjt
  • 17 Answers
SOURCE: My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
Posted on May 17, 2009
SD Tech
  • 14553 Answers
SOURCE: The TV was working great
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Posted on Sep 28, 2010
Testimonial: "The light blinked two times, then 1 time then repeated."
I press bottom tv comes on then goes back off
On this model the power board will need to be completely resoldered, that is your problem.
Nov 29, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
When I press the 'power' button, I hear it click, but no picture comes on. I hear it click a couple more times, then it stops.
If it clicks then goes to standby, then the fault is in your power supply circuit. If the sound comes on then the fault is in the line timebase circuit. Aquick way to check the line circuit is to place the back of your hand about 1" from the screen as you switch on, you will feel the hairs on your hand standing to attention.
Feb 24, 2010 | GE 31GT740 31" TV
May 16, 2009 | Televison & Video
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sony KV-36HS20
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Jan 28, 2008 | Sony KV-35S45 35" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
