Vistron 32" tv will not recognise pc port or hdmi as pc monitor
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: vistron remote codes for sky
TV maker is Palladium codes are 0560, 398, 391, 446
Posted on Oct 14, 2008
SHOGUN125
  • 58 Answers
SOURCE: using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Posted on Jan 31, 2009
  • 4234 Answers
SOURCE: my sharp tv is pc ready. I hook everything up and
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Posted on Mar 13, 2010
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
How to use tv as computer monitor
A lot will depend on what computer you have. If your computer has got an HDMI output then you can connect this port to the HDMI input of the TV using an HDMI cable. Then in windows control panel of computer you select Display properties and select the monitor port.
Aug 18, 2014 | Samsung 32" Class Full HD 1080p 60Hz...
I want to know how to hook up my PC to this TV as a monitor. The manual says to use HDMI 1 port and the DVI port on PC. Do i need to get adapters to make such a connection
an hdmi cable will do then hook up to hdmi port 1 and on tv select that input and it should work. of course the hdmi cable has to be hooked up to hdmi input on computer
Jul 08, 2012 | Magnavox 32MF339B 32 in. TV
My TV (42" Full HD
Yes you can - but not with a USB cable. USB is only for data (file) transfer.
What you are attempting to do is use your TV as a PC monitor, therefore it needs to be connected to your TV using a PC monitor cable (15-pin D-SUB/VGA). You will also need a separate audio cable from your PC to your TV if you want to use the TV speakers for audio. If you are using a receiver or amplifier with external speakers, you can connect the audio out from the PC directly to the amplifier/receiver.
It is also possible to connect the PC to the TV with an HDMI cable if your PC has an HDMI out port. However, some TVs wont accept an HDMI signal from a PC and this method of connection can cause other issues, so I would recommend using the PC monitor cable method.
Please let me know if you need further assistance.
Regards,
BElectric
Jan 08, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do you use tv as pc monitor
if it has a hdmi port then you can use it as a pc monitor,plug in the hdmi cable through your cpu or laptop then,select hdmi as your tv source
Dec 14, 2010 | Sylvania LC320SSX 32 in. LCD TV
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
MY PC DOES NOT HAVE A HDMI PORT CAN I USE MY PC MONITOR CONNECTION CABLE TO CONNECT TO MY AKAI LCT3285TA 32 PLASM [THERE IS A PORT ON THE BACK OF THE TV BUT I GET NO SIGNAL...DO I NEED TO MAKE SETTING...
Look at the function keys (F1 to F12) in your computer since there is a shortcut key in it. Look for a key with an icon resembling like a TV and a PC Screen with a slash. It's like TV/Monitor icon.
Now with the PC (laptop?) hooked with the TV, (the tv showing no signal), hold down the FN key and press that function key with the TV/Monitor icon.
Jun 04, 2010 | Computers & Internet
Using my Samsung LCD TV as monitor for my Sony Vaio Laptop
Jan 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sky TV Remote Control Code For Vistron 40" TV Required
Jun 27, 2008 | Televison & Video
Vistron remote codes for sky
Jun 11, 2008 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
