Question about Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag
Belt sander clogged dust collection
Porter cable 362 whisper sander. dust shoots out front, not up vacuum tube
  • 3 more comments
  • wpbco Jan 11, 2009
    porter cable 362, whisper, belt sander won't pick up dust. can i take apart?
  • Anonymous Mar 21, 2014
    How to install a new drive belt
  • Anonymous Mar 25, 2014
    how do you open the dust collector
    how to empty dust collector
  • Anonymous Mar 28, 2014
    trouble shooting
  • 58 Answers
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Posted on Jan 10, 2009
  • Michael Mittelsdorf
    Michael Mittelsdorf Jan 11, 2009
    Taking apart this sander is more trouble than its worth.  Have you tried cleaning the dust tube as I suggested.
  • berdman Mar 18, 2015
    dust tube is clear, still shoots dust out front.
Where would I locate wheel rubber for sander Toledo tbs 800
Sep 15, 2012 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter cable 352vs manual
My Porter Cable 352vs Belt Sander was clogged from sanding epoxy, wet wood, something like that. No dust collection at all.
I had to remove 4 screws on the housing, one screw under the front handle and another below the rear handle. The housing came out very easily (with a little wiggle). Pay very close attention to where the position of your plastic fan housing sits. It will only be installed in one spot.
The pdf diagram was not exactly correct on the housing placement.
Once opened, The wood and epoxy were caked in everyplace. I brushed them out and replaced the screws.
Good as new.
Good luck.
Feb 24, 2012 | Tools & Hardware - Others
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 362 belt sander - the paper slips off
there might be a buildup of sawdust in the tensioning mechanism or the yoke might be bent. I would look at excess buildup in the mechanism first. there are 3 screws on the outside of the tool so you can remove the assembly as a whole. try and clean as thoroughly as possible. the mechanism should move freely and "snap" when lever released.
Jul 18, 2010 | Porter Cable Tools & Hardware - Others
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
I have a porter cable belt sander that shoots dust out the front. It has a dust bag but the wood dust doesn't go in the bag. it used to. I have taped up some weak parts of the bag but I am not sure what...
the inside of the tool is full of dust not allowing it to get into the bag. I have had to completely disassemble and clean the track for the dust. You can try blowing thru every port with compressed air and see if that helps.
Nov 09, 2009 | Porter Cable 3" x 21" Electronic Variable...
My porter cable 362 belt sander will not adjust enough to center the belt. When the thumb adj. screw is completely free (lose), it rides about halfway across the roller and stays. I can't bring it back...
The slide arm mechanisms and tension arm, springs, etc. need a little light machine oil, 3-in-1, to make them slide easly, a few dropes will do the trick, do not over oil. Move the adjustment knob just hair at a time or it will over adjust, hope this helps you.
Mar 16, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Smells like wires buning
Motor may just need new brushes, Cooling vents may be clogged with dust. or bearings in the motor or front roller maybe bad. Causing excessive drag
blow it all out with compressed air or shopvac
look for external brush caps (2) oppsite from each other take them out to be sure they slide freely, sometimes one gets hug up and doesn't make good contact
Mar 12, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 362 12 Amp 4 Inch By 24 Inch Belt Sander With Cloth Dust Bag Logo
1,216 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
