Question about Vtech V.reader Animated E-book System
V tech storio starts up in engineering mode help
Starts up in engineering mode how do i resolve this problem
Storio vtechi downloaded the storie from the website to the file manager but cant get them to transfer to the storio, it startts to transfer then says error!!
are you using an SD card? You need an SD card for this. If you already are and you are still getting an error, make sure that the SD card is not write-protected.
Nov 29, 2013 | Vtech Storio Interactive E-Reading System...
Vreader/storio sd card update failed
Try to update your SD-card from another computer. That worked for me.
Jul 13, 2012 | Vtech V.reader Animated E-book System
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
My Vtech V-reader freezes on calibration screen
I just found a solution to this: Turn off the vreader, then press & hold the help "?" button. While holding the "?" button, press power. My system bypassed the calibration step and booted correctly.
Jan 05, 2012 | Vtech V.reader Reading System
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
Dec 28, 2011 | Vtech V.Reader Interactive Reading System
It keeps saying touchscreen calibration utility touch crosshair to calibrate. we'v done everything that we could to fix it. it will not go back to the page with activities.
I need help I buy my son V.reader for Christmas it say Touchscreen Calibration Utility Touch Crosshairs to calibrate. I need help? how do I fix it?
Aug 19, 2011 | Vtech V.reader Animated E-book System
SCX-4521F All-In-One Laser Printer: toner empty after replacing new toner of samsung s...
Clear/reset the settings on the printer. Press in this order w/o pausing:
menu
193
start
If you do it correctly, the LED will say "Select Country, US", then you press "OK", then it will clear the settings and the error message should go away unless you have a dirty sensor or your toner is installed incorrectly.
Good luck-
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How to remove the preview mode
any tech support person will need more info to help resolve, make of camera, card type, how are you using setup, version of OS????
Jun 21, 2008 | Computers & Internet
Vtech V.reader Animated E-book System Logo
41 people viewed this question
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
