Question about Elna 1010
Serger blades do not cut.
Elna serger pro dex704: the cutting blades do nothing. Not old enough to even replace, no barbs etc., and have put in the 2nd blade (never used) to no avail. Have adjusted the moving blade up and down, no change. Sewing on cotton knit (t-shirt). Fabric seems to rag and not cut. All cleaned. Suggestions? SJ
  • chudleighval Feb 06, 2009
    Hi , I have lots of problems with this machine. I just cannot get the tension correct. Also my fabric[stretch t-shirt fabric] keeps jamming up against the rolled hem thingy !!! and then over the upper looper and then the needle snaps !!!! I bought this machine second hand last Friday and have struggled and struggled all week !!! Are you totally sorted now ? or do you still have problems ? Can you offer me any suggestions ? apart from putting it on ebay !!! Thanks
  • onlybyhisgra Apr 03, 2009
    same problem. singer serger brand new. please email me info!
    onlybyhisgrace.fp@gmail.com
    thanks and GOD bless you!
For now, it works only satisfactorily:
I applied alcohol to further clean both blades,
dried and then oiled them. There seemed to be a slight gap between blades;
the fabric was dragged into the gap instead of being cut.
Posted on Jan 13, 2009
Hi every body,I need Elna dex704 overlocker manual,without manual I feel very difficult to use it.
Hi Noreen,
Consider joining the discussion Elna Serger user group on Yahoo that is linked below, for they should be able to locate a manual for you, as well as give you additional advice on how to get the most out of your serger.
https://groups.yahoo.com/neo/groups/elnasergers/info
Jun 12, 2016 | Elna Sewing Machines
Why did it suddenly stop cutting?
Please provide the model of your machine.
Ok, it's a serger. Wondered why a sewing machine would be cutting unless it had the cut-n-sew accessory.
Most likely the blades are damaged or malfunctioning. Is the blade still moving when it is stitching? Is it just chomping away at the fabric but not cutting? If so, either or both blades need to be replaced. Consult your owner's manual. Usually only one blade can be installed without any technical knowledge. You can probably order the replacement blade and install it yourself. However, the other usually needs to be replaced by a knowledgeable technician because it requires some precision.
Has the blade stopped moving at all? If so, how long has it been since a thorough cleaning and oiling? Take it for service.
Mar 25, 2016 | Elna Sewing Machines
Rger Elna 614de the button on the side w ill not bring up the upper blade from down position?
it's possible that there need to be a adjustment to the serger or there could be a damaged or broken part in it, having it checked would be a good idea
Mar 27, 2015 | Elna Sewing Machines
How can I do adjustment of cutting width elna overlock machine
to change how much fabric is cut you need to move the cutting blade either left or right, this overlocker is one of the first so I think this process was pretty manual, ie using a screw driver to release and reposition the right hand blade.
it may be worthwhile buying a manual for this while you still can get them, this model was released back in 1987 in UK. Instruction Manual Elna L1 Serger
Feb 27, 2015 | Elna Sewing Machines
I replaced cutter blade on Elna PRO DC 5. New blade won't cut fabric. how do I adjust it?
All sergers have 2 blades. Just like scissors. Only 1 blade of scissor is sharp = not good cutting.
Feb 14, 2014 | Elna 1010
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
Jan 05, 2008 | Simplicity Serge Pro SW432 Mechanical...
Sewing Machines Logo
853 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
