Question about HP LaserJet 2420 Printer
Printouts have marks on right side of paper
When printing we are getting 4 separate marks on the left side of the paper. The marks are from the previous document printed and are 1/4 inch in from edge of paper and 3 inches apart.
  • HP Master
  • 1,121 Answers
1. Check with another cartridge.
2. Replace teflon sleeve if its available or replace fuser assembly.
Posted on Nov 29, 2012
shortyz1123
  • 9 Answers
SOURCE: scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Posted on Jan 07, 2008
SOURCE: Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Posted on Jul 30, 2008
Joed911
  • 4338 Answers
SOURCE: 2430 printing 1/2 inch marks down left side of page
Did you change the Toner cartridge? If that did not fix it :
Then the Fuser needs replacing. If you take the Fuser out from the rear, and rotate the drum in it, you will see the marks. You can try to clean it but experience shows that you will have to replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 13, 2008
KingDWS
  • 1606 Answers
SOURCE: Bad Printing and Stripes on Printed Sheets on HP 1100A
It isn't a fuzer problem it is most likly a image drum problem. To fix you have two choices replace the image drum with a oem part or a refurbished part or replace the printer. sometimes it is cheaper to get a replacement printer than to replace this part.
Posted on Dec 30, 2009
  • 131 Answers
SOURCE: HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Posted on Apr 21, 2010
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
How do i set print margins? cant get the information to line up correctly? documents print but dont line up on pre printed tickets.
Unlock the tractor and try moving the paper to the left or to the right to align the printout with the paper. Then lock the tractor again.
Nov 17, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
I have downloaded the printer drivers for my HP Deskjet D2460 from the HP site but I have no printer toolbox and therefore cannot clean cartridges etc. Can you help
Hi Kimsmith99
Please do not worry. You can try the following.
1. Simple take the cartridges out from your printer.
2. Use a clean cloth and some distilled water.
3. Clean the copper connections of the print cartridge gently with the help of the clean water and a clean cloth .
4. Take a tissue paper and then try to mark a stamp from the cartridge print head on that tissue paper.e
5. Do it till you get a clear color / black parallel line on the tissue paper.
6. Once you get a clear parallel mark on the tissue paper, insert the cartridge back in to the printer and the take 2-3 printouts.
7. You will get the clear printout for sure. This is my practical experience.
Thanks & Regards
Ashish Rohilla
Aug 21, 2010 | Office Equipment & Supplies
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
How to configure printhead alignment
Hi there, Aligning the Print Head
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
Hope this help.
Have a good day.
Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
Each time I print on plain paper the paper feeds into the machine and when it hits pinch rollers after the print head, the top right hand corner is turned over. Two pages later and the third page is so...
Follow these steps to reload paper:
  1. Flip the feeder guard forward.
  2. Remove the paper and make sure it's not curled or wrinkled.
  3. Fan the stack of paper to make sure the sheets are separated.
  4. Reload the paper against the right edge of the sheet feeder andslide the left edge guide against the other side, but not too tightly.
  5. Don't load paper above the arrow mark on the left edge guide.
  6. Make sure the printable side of the paper is facing up.
  7. Flip the feeder guard back.
  8. Once you have completed the steps above, press the cp_button_6.gif Start button.
Mar 07, 2009 | Office Equipment & Supplies
HP LaserJet 2420 Printer Logo
171 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
