My Western Digital?s 250GB Passport (WD) wont wok the blue light comes on but nothing happens and i thought if i chage the cord they will save my pics and other things but that didnt work either what can i do
  • 1 more comment
  • shakima82 Jan 11, 2009
    no it dont
  • shakima82 Jan 12, 2009
    how much would data recovery cost on it
  • ramosrich May 11, 2010
    Greetings.
    Does it work to other computers or laptop? we need to know if it does so we can isolate the problem.
  • 36 Answers
Does your passport have driver or cd included? if there is try to install the CD first.
If you have tried it and it wont work we can safely say that the hard drive might have a failure. If your hard driveis under warranty ask for a replacement and ask if warranty includes recovery of data.
Hope that helps.
Posted on Jan 11, 2009
  • ramosrich Jan 12, 2009
    Greetings.
    I dont have any idea as to how much they are charging in your location. but they do charge it by size like (example) 1$ per gigs, but you can go to your local technician and have them look at it, there is another method where they can directly hook it up to a laptop, if it works, then it means that the hard disk is fine but the "enclosure" is busted.
My western digital wd passport 250gb shows up as drive "d" but goes away
Make sure it is connected properly, normally when this happend it means the USB connection is loose.
Feb 15, 2011 | Western Digital WD Passport 250GB Portable...
How do i unlock the password on my wd portable passport 750GB??
Unfortunately Western Digital say that there is no way to reset the password on their passport drives.
Jan 16, 2011 | Western Digital WD Passport 250GB Portable...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
Its a western digital WD passport 750GB portable drive and its not showing up on my computer. I can see the blue light and feel it running but not registering on the laptop or desktop
Usually what has happened here is the usb interface has failed. The little hard drive with all your data is perfectly fine but the interface can no longer talk to the computer.
There are a couple of fixes. One is to send it in to WD who may or may not preserve your data. You can buy another passport and take the drive out and put it into the new drives enclosure. And third which is the way I've been fixing these is to go buy a usb drive enclosure. These start at $15 and up. Then you just take the drive out of your passport, plug it into the enclosure and you are back up and running.
This type of failure is common to all manufacturers.
The enclosure swap is something you can do yourself. The hardest bit is actually opening the case on the passport. Any computer shop should be able to do it for about $40 or less.
Sep 29, 2010 | Western Digital WD Passport 250GB Portable...
Light comes on but computer doesnt show
Try the following steps:
1. Plug the USB Cord into another USB Port on your PC
If no result then
2. Replace the USB Cord
If no result
3. Try connecting it on another PC
Aug 05, 2010 | Western Digital WD Passport 250GB Portable...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
