Question about Element Electronics FLX-2610 26 in. LCD HDTV
Where is the game mode setting on element flx-2610 26" tv
Has the worst lag in the world....Don't know what to do about it. Seems like every setting has major lag. 480-lag, 720-lag, 1080i-lag, 1080p lags......Is there a fix......Please let me no ASAP........
SOURCE: Can't remove stand from Element flx 1910 TV.
On the bottom of the Element FLX-1910 there are 4 tabs located on the bottom side of the base. With the help of another person, please slide all 4 tabs in an inward direction. This will release the tension between the base and the stand. Slide the base over the tabs and remove the base from the stand.
Posted on May 30, 2009
  • 4090 Answers
SOURCE: Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
Posted on Aug 14, 2009
SOURCE: hi, i have a flx-2211b element electronics tv and
I have the same problem with my 360 i am just going to by a new tv i cant find the remote code. or any thing and the hdmi port don't work that's my answer this TV sucks and it is ****..
Posted on Jan 10, 2010
  • 10865 Answers
SOURCE: what are the steps to
Hello. here is a link to a free manual for your tv. download it and it will give you all of the steps http://www.retrevo.com/support/Element-FLX-3210-TVs-manual/id/4540dj094/t/2/
J.
Posted on Sep 14, 2010
  • 5103 Answers
SOURCE: how to fix element flx-3210 that has sound but no
It's probably a backlight or backlight inverter issue if the problem occurs on all sources and the onscreen menus. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx. Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Jan 05, 2011
Can't locate "game mode" setting
then there probably is not a game mode . I have had several and none have had a game mode but my grandson uses the vizio all the time .
Jun 28, 2015 | Sylvania LC320SLX 32 in. LCD TV
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Feb 26, 2013 | Element Electronics FLX-3211B 32 in. LCD...
My nintendo 64 is lagging!
The N64 was originally made for the old analog CRT TV, if you are connecting it to a newer type digital TV this could be why you experience lagging as I have those games and do not remember any lag in any of them not that I have played them in the last 2 years. The worst case scenario is that the seller was getting rid of it due to a bad Video chip inside the N64 without stating that there was a problem with it so they could sell it. This is why I never use eBay you just never know what you are getting. I am not sure if Nintendo still support this console but it maybe worth a try to contact them directly and see if they are able to help you figure out what it is.
Your English is very good I understood everything with no problems my friend.
Jan 14, 2013 | Nintendo 64 Console
NO Picture ~ only sound
If you have back-light but no picture the problem is T-con board but if the TV don't have back-light the problem is inverter board..
Replacing one of the board will fix the problem..
Hope it helps..please rate..
Mar 11, 2012 | Element Electronics FLX-3211B 32 in. LCD...
I have an Element FLX 3210 that won't light up and show a picture..it has the sound but no picture.
Check the two caps (10uF 450Vdc) by the inverter transformers, also check fuse F2.
Worst case will be shorted out ballast caps in the LCD panel assembly.
http://s807.photobucket.com/albums/yy352/budm/Element/Element%20FLX-3210/
Jun 04, 2011 | Element Electronics FLX3210 32 in. LCD TV
My picture seems oversized so when viewing it you cant see everything.
What source are you using? Cable Box? Cable tuner? DVD? Computer?
Most of the time your TV's remote will have a button that says "Aspect" or "View Mode" or "Zoom" they can stretch zoom and distort the screen and cause this.
If it is a DVD or Set Top Box you may have to go into the menu or set-up screen and change the aspect ratio to that of your TV.
Let me know if that helps, any more details would be great.
Thanks!
Jan 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Element Electronics FLX-2610 26 in. LCD HDTV Logo
155 people viewed this question
Top Element Electronics Televison & Video Experts
Josh Whitehead
Josh Whitehead
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
