Question about Toshiba 56HM66 56" Projection HDTV
Toshiba 56hm66 bulbs popping
My Toshiba 56hm66 Theaterwide HD tv popped a bulb. I ordered a new bulb and installed it and 15 mins later it popped. Is there something wrong with my tv or did I just get a bad bulb?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
May have got a bad new one or ballast board in set is bad. It powers the lamp.
Posted on Dec 22, 2012
cammykins
  • 149 Answers
SOURCE: 62" Toshiba Theaterwide HD DLP
If your lamp imploded then your product is perm. damaged. You could have a service center come out and try to clean it, however, by the time you pay for that if its not under the warranty then its going to probly cost you just as much as you might as well towards a new one. Also, Toshiba is one of the worst manufacturers that has issue on their HM195 or HM95 series. They had plenty of recalls going on with that series. If you own that model, you might want to see if the manufacturer can do something for you if you are still within the recall guidelines. Use this as a tool: Click on: "Replace lamp" This is Samsungs website, however, replacing a DLP lamp is the same process in every manufacturers products. Use the prompts in the pop up you see from there. See if that helps. http://www.samsung.com/us/support/guides/howToGuideSearchList.do?group=televisions&type=televisions&subtype=dlptv&model_nm=HL-T6756W&dType=D&mType=UM&vType=R# Good luck!
Posted on Sep 07, 2007
  • 298 Answers
SOURCE: Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Posted on Apr 10, 2009
  • 1779 Answers
SOURCE: Toshiba Theaterwide HD 50 inch convergence problem
You will have to spend money to repair it. The Convergence IC's need replacing along with checking all the bias resistors for correct value. Do not attempt to align the Blue manually as you will have a headache once the problem is repaired. A normal repair bill is in the area of $250.00 for a service center to repair.
Posted on May 28, 2009
  • 41 Answers
SOURCE: Toshiba Theaterwide HD 52 in rear projection TV,
Possibly bad electrolytics. Generic answer but you didn't give a complete model number.
Posted on Jul 07, 2009
  • 630 Answers
SOURCE: My Toshiba 52HM84 blows bulbs
Ensure that you don't handle the bulb with bare fingers. wipe the bulb with meths and hold the buld with a lint free cloth when you're putting it in. If it's still blowing it's probably over heating so check the fan
Posted on Aug 22, 2009
TV programs filmed after sunset need to be brighter
Old technology. Clean the optics and replace the bulb. Better off buying a new LED flatscreen in 4K Ultra HD :>)
Mar 07, 2018 | Toshiba 56HM66 56" Projection HDTV
Toshiba TheaterWide 57HM167 Won't Turn On After Bulb Replacement
There is a ballast which drives the lamp--a hint would be to try to be in a position if possible to see if lamp ignites at all or even for a moment.
The ballasts do fail but rarely----it develops about 12,000 plus to the lamp and is much like spark plug wires as far as rf.
Some checks would have to be made and then the ballast priced--google the model number with ballast after it to get and idea.
No cut and dried solution here--several possible causes.
Mar 16, 2012 | Televison & Video
Aug 22, 2009 | Toshiba 56HM66 56" Projection HDTV
May 28, 2009 | Toshiba Televison & Video
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Red light flashing while green light stays on
I have the same TV, your projection bulb has quit/failed.
A loud pop was heard and the picture has gone followed by a red led fault light clicking on and off.
if your tv is less than 1 year old, and you registered it with Toshiba, you could qualify for a free replacement.
otherwise expect to pay 200.00 for a new bulb from Toshiba.
only good thing is you can replace it yourself, only tool needed is a phillips screwdriver.
you can check EbaY for prices less than 175.00 to 150.00
i am on my 3rd bulb within 4 years....
good luck!
Aug 19, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
No Picture.
good luck!
Jun 07, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Aug 13, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 56HM66 56" Projection HDTV Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
