Question about Cameras
My kit lenses, Canon 18-55mm stopped going till F/3.5, even using it in 18mm. Now the mininum it goes is F/5. Any solution for that?
Normally, at 18mm, the minimum aperture would be F/3.5, but it's stuck in F/5.0. Is this something that can be solved by myself?
  • 685 Answers
If you are focusing very close that may be a consideration. But if it does not change at any focal length, and focal distance then it will need to be repaired. Or, try KEH.com for excellent quality used lenses. That lens can be replaced to the same or less than a repair.
Posted on Dec 15, 2012
SOURCE: tamron18-200 f/3.5-6.3
Tamron has identified this problem with the Canon. See link: http://www.tamron.com/about/updates_canon.asp, but I am not sure about your Nikon.
Posted on Dec 31, 2007
  • 73 Answers
SOURCE: I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
Posted on Jul 27, 2009
  • 102366 Answers
SOURCE: WHAT DOES A LOCK LENS APERTURE RING AT MINIMUM
Having gone over a month without a response, I assume this is no longer a problem.
Posted on Jul 15, 2010
  • 14 Answers
SOURCE: Hi. Canon EOS 40D + canon 50mm f/1.8 II. when I
I think you should upgrade you cameras software firts.
Posted on May 02, 2011
  • 102366 Answers
SOURCE: aperture ring won't turn
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
Posted on Sep 30, 2012
My lumix dc20 when turned on displays this battery cannot be used. Any ideas please
1) Incorrect battery, use genuine battery. 2) My Canon 400D had a similar problem. Checks showed that I had a damaged standard 18mm to 55mm lense unit, and also gave me "change battery" error message. I had a similar problem with a 70-300m lens. The camera main lense needed repairs, the Tacumar lense was not worth repairing. Have a camera specialist check your camera and more specific the main lense unit.
Jun 08, 2014 | Cameras
Why does my lens only zoom to 200
Could be, because most camera's only can auto focus till f/1:5.6. And if 5.6 is reached at the focal length of 200 mm, the camera stops it from going to a part it can't be focused.
Perhaps you try the lens in manual focus, and manual zoom.
Jan 28, 2014 | Sigma Zoom Telephoto 170-500mm f/5-6.3 APO...
How to clean camera and lens contact
Use Vacum blower, lens cleaner and soft lens cleaning cloth only.
Oct 30, 2012 | Sigma 18mm - 250mm f/3.5-6.3 DC OS...
Have a 13 month old Sigma 18-250 lens that has been working fine up until 3 weeks ago when i get Error 01 message that there is a communication problem between camera and lens, please clean contacts. Have...
Hi, I am having the same problem with the same lens. Only news I have found so far was in a spanish language forum, used google translate and it sounds like the guy had to have it repaired. In my case, the lens is about 18 months old and I find other lenses work fine on my T2i. The forum I read mentioned a ribbon cable within the lens that can break, but the translations were too poor to tell if it was the problem for sure or not.
Jun 17, 2011 | Sigma 18mm - 250mm f/3.5-6.3 DC OS...
Aperture won't go below 5.0 even when zoomed all the way out to 18mm... help!
Hi, did you get any solution? I have exactly the same problem with my nikkor 18-55mm f/3.5-5.6, my f/ won't go below 5 even if it is all zoomed out
Feb 07, 2011 | Tamron 18-200mm f/3.5-6.3 for Nikon
Cant use f/3.5
You will only be able to use the f3.5 aperture setting when the lens is zoomed out to the 18mm setting. As you zoom in, the maximum aperture available will decrease until you reach the 55mm setting where the maximum aperture will be f5.6.
Check to see if you can obtain f3.5 with the lens zoomed fully out. If not, it sounds as if the aperture blades could be sticking, in which case it will need to be professionally repaired.
Hope this helps!
Jun 12, 2009 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Can't get F3.5 aperture on the 18-135mm kit lense on d80
You may be shooting auto and there is too much light. If you want to be sure you are shooting with 18mm @ f3.5 then shoot with aperture priority (the shutter speed will adjust automatically). Ususally at a wide focal length you would want a small aperature (smaller f-stop) so this should not really be a problem.
Feb 14, 2009 | Nikon D80 Digital Camera with 18-135mm...
Tamron18-200 f/3.5-6.3
Dec 07, 2007 | Tamron 18-200mm f/3.5-6.3 for Nikon
Cameras Logo
32 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
