Question about Lexmark X83 All-In-One InkJet Printer
Paper keeps jaming
The paper keeps jaming its a lexmark X83
  • 2 more comments
  • farrout49 Jan 10, 2009
    how do i fix this problem please send instructions
  • kbricebowe Jan 13, 2009
    paper keeps jamming.paper is sucked in from the center which causes it to jam
  • mendinspud Feb 11, 2009
    paper keeps jaming in my new lexmark x5070 allinone printer
  • flemingw Feb 13, 2009
    I have the same problem, the paper is pulled half way into the printer and stops. The machine indicates that there is a paper jam but I can not find it. How do you open the machine without damaging it.
  • 431 Answers
Problemwith the roller or with the gear which is attached to themotor
Posted on Jan 10, 2009
If I schedule a print for my Lexmark X83 it feeds one sheet of paper straight through to the tray but does not print anything. No alarms anywhere on system. Same thing occurs if I ask for test print or...
Sounds like a clogged print head. In the lexmark printer software there should be a maintenance tool where you can try and clean the print heads.
By the same token the X83 is about 10 years old and well past the life cycle of most ink jet printers so if the troubleshooting tools don't get it back in order, it will be cheaper to replace than to repair.
Jul 09, 2011 | Lexmark X83 All-In-One InkJet Printer
My lexmark x83 is making a clicking noise and will not pull paper through.
hello, the problem with your machine is a gear that drives the paper feed section, not the paper feed roller but the platen roller, well its cracked, unless you have an identical machine, you will not be able to repair this printer, i have tried. so, this machine has performed for you extremely well, but now it time to look for another one. sorry
Oct 07, 2010 | Lexmark X83 All-In-One InkJet Printer
How do I remove the cover of my lexmark X83? The paper will only feed part of the way then I get a paper jam message.
there is a cover there at the back of your printer, pull it down then remove the paper hang on their, then after you remove , check if there is another paper to hang, after that try to print
Jul 01, 2009 | Lexmark X83 All-In-One InkJet Printer
Paper will not feed
its a software issue for me..
I suggest that you will load compatible firmware to your printer...
that's why the printing performance of your printer is very slow..
thanks for using FIXYA.
good luck.
May 21, 2009 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 has system error A04.
Try to do the following:
  1. Reseat both cartridges in the printer and unplug the power cable for 30 seconds.
  2. Plug the power cable back in.
If you still experience issues please let me know.
Mar 30, 2009 | Lexmark X83 All-In-One InkJet Printer
X83 lexmark A06 error (paper jam)
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Lexmark X83 All-In-One InkJet Printer
You will find the solution for this on this site
Choose the Location
then type the mode number
there is a page with the solution available for this problem
Dec 16, 2008 | Lexmark X1150 All-In-One InkJet Printer
Paper won't feed in my Lexmar X83
insert sandpaper into printer tray. begin print. hold the sheet tightly and DO NOT let the printer feed it in. it worked with my lexmark z611.
Jul 23, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 all-in-one printer
Hi gerby, need to eliminate a few issues to get to the cause. First, check for a jam. Paper jams can be so tiny you can barely notice them. Use a torch and check thoroughly down back of unit in paper feeder, open cover, let cartridge carriage roll left and settle. Now look inside thoroughly too. If no jam, check rollers are even and look same on each side. Post back if no good.
Sep 01, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
