Question about Bose Lifestyle 35 System
Optical audio output from Apple TV to Bose System 35 Optical input used to work but now not working. It had worked and I have checked Monster Optical Cable, as well as the Bose input and both worked with other devices. I went to Apple Store and got a replacement Aplple TV box and that still did not solve issue. Is this a software problem with Apple TV'sfeed to the Bose Optical input.
SOURCE: Sony Audio Optical Out to Bose Optical In not working
Set the source for Optical-In on the Bose system to TV
Posted on Feb 17, 2008
SOURCE: hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Posted on May 31, 2010
  • 11800 Answers
SOURCE: I have a Bose lifestyle system that is about 10
The only outputs that can carry audio from your Apple tv are the HDMI and optical ones. HDMI is out - an 10 year old system will surely not have it and if your Bose doesn't have an optical in connector then you will need to use this
http://www.hdtvsupply.com/difiopttodic.html
It comes with the required optical cable; you will need to buy an extra stereo RCA cable.
Posted on Dec 09, 2010
adamncc1701
  • 158 Answers
SOURCE: Is it better too hook up a optical audio cable
Hello, its always better to go the shortest route this would be ps3 right to the bose there are too many menu variables ,circuits, that would be involved if you involve the tv output as well. that theory applies to video as well always go directly from source to load without any additional switches (circuits) when possible.
Posted on Feb 22, 2011
hunterr
  • 36 Answers
SOURCE: I try to plug apple
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Posted on Mar 01, 2011
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
How to hook up a DVD DIGITAL PLAYER, VCR , Bose Cinemate 2 to 1 DIGITAL ,PHILIPS5704D/F7
Connect the optical output from your TV optical out to the optical input on your Bose system. From that point on, any audio that is sent to the TV from any source or input will be played back on the Bose system.
Jul 11, 2014 | Televison & Video
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
Jan 24, 2011 | Bose Lifestyle 30 System
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Trying to connect to LG 60 inch plasma. no output
Hi.
You need to connect the Bose using the Optical Audio output from TV to Bose main unit (kind of square shaped connector), and not using the RCA inputs on TV.
The picture below is an LG back panel, the optical audio connector is at the lower side of I/O connections at the back of TV, on some model the location of connector may be different.
Dec 26, 2009 | Bose Cinemate Digital Home Theater System...
Pretty much the same problem
I have the same system. I have a Lifestyle and a Sony TV with a Samsung Blueray player. I also have an X-box 360, plus my pc with all my CDs (I-tunes) plays through my bose. Do this:
1. Use the optical cable for the blueray player to the Bose (AUX).
2. Use a digital audio cable from the cable box (either black or orange output) to the Bose CBL-SAT digital input. (it's a single audio cable)
3. For my PC, I'm using a digital cable from the pc to the Bose. I'm using the TV output because it's empty.
4. For my x-box (which I'm not too happy about) I'm using regular red-white audio cables from Bose TV input directly to the TV audio out. (You can play all of the above through this channel, but don't).
I figured the most important high quality sound should come from the blueray player and from watching regular cable tv. For picture, you should be using all HDMI connections.
Hope this helps.
MC
Jun 26, 2009 | Bose Lifestyle 38 DVD Home Entertainment...
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Bose Lifestyle 35 System Logo
211 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
