Question about Microwave Ovens
I am reinstalling a frigidaire plmvz169gcc microwave. i don;t have the template. What should I do?
5 Suggested Answers
  • 18 Answers
SOURCE: Reinstallation of microwave on tile - template or picture?
contact GE with modle number and they will send you one
Posted on Jul 28, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: No readout on display for my plmvz169gcc
We regularly repair these oven displays / controllers for $39.95 nationwide. Details and a helpful video are here.
Posted on Jan 08, 2011
walesarumi
  • 6993 Answers
SOURCE: I'm looking for a repair
The truth is that the repair manual for your Frigidaire microwave is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of this unit via phone or e-mail and request for the repair manual from them. They might give it to you or direct you to a dealer where you can get the repair manual.
This is the best you can do to get the repair manual you are requesting for.
Go to Frigidaire's website, check "Contact Us" and you would see their e-mail and phone number.
Additional information concerning your Microwave's Magnetron;
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged.
Good luck.
Posted on Jan 13, 2011
SOURCE: My Frigidaire microwave model# PLMVZ169GCC
Intermittent load noise (usual intermittent pulse noise is exaggerated) and the food is not heating though everything else seems to opperate normally: The Triac or Diode is capute.
You need to replace this part (@$30), but first need to discharge the capacitor, which is dangerous. I am going to give it a "shot", and not a "shock", all the punn intended. I will use an long insulated screw driver to touch both of the 2/3 tines of the adjacent capacitor, which will give a load "POP!" 2-3x to insure the stored energy is diffused.
Then, hopefully, simply replace the longe wire diode.
TaDa!
Posted on Feb 26, 2011
Plmvz169gcc lost power
The service manual is here.
It may be a defective 20A fuse, a blown magnetron temperature fuse, or a problem on the control circuit board, which can be economically repaired.
There is a YouTube video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the controller is off, you should be able to access the magnetron's temperature fuse for testing and possible replacement.
You can order parts from the Pros here.
Jan 10, 2013 | Frigidaire PLMV169DC Microwave Oven
All Frigidaire PLMVZ169GCC Microwave Oven problems
Hello Roger Oesterling - If the microwave is not heating properly, it could possibly have a faulty control panel, magnetron or an issue with the power supply. Contact a professional to move forward accurately for a proper diagnoses.
Jan 01, 2013 | Frigidaire FMV156DC Microwave Oven
No readout on display for my plmvz169gcc frigidaire microwave
Jan 04, 2011 | Frigidaire Microwave Ovens
My Frigidaire microwave model# PLMVZ169GCC does not heat food. It runs and makes a loud noise, the plate turns but does not heat up. It is only 2 yesrs old. Thank you for your help.
TaDa!
Oct 22, 2010 | Frigidaire PLMV169DC Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Jan 10, 2010 | GE Profile Over-the-Range Microwave
Hi there, I'm installing an LG LMV205SW OTR Microwave and the four holes for the mounting plate do not coincide with the two wall studs that are behind the microwave location. Can I sink a couple of extra...
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
Dec 29, 2009 | LG LMV2083SW Microwave Oven
When installing over the range microwave does template need to be removed
the paper template that they send to mark for mounting instructions? yes...another template you're refering to?
Oct 25, 2009 | Bosch Microwave Ovens
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
