Question about Dell OptiPlex GX620 PC Desktop
I recently ordered an older version of Dell OptiPlex GX620 with networl card. Now, I already have wifi in my home. Will I be able to get on the internet with just that?
  • Dell Master
  • 7,627 Answers
You should be able to connect if the network card is enabled and working properly. Just do a search for Available Wireless Networks, Select your SSID and enter your security code. That said, you can use the Wired Ethernet as well, providing your wireless access point has ethernet ports on the device. Wired , of course, is faster.
Posted on Nov 29, 2012
  • 61 Answers
SOURCE: Dell Optiplex GX620 not recognizing PCIe video cards
If you have the PCIe card installed and boot the computer, do you still have video on the onboard connection? If so the two may be in conflict with each other. You may need to disable the onboard video card in order to get the newly installed card working.
Posted on Aug 28, 2009
bschilz
  • 2049 Answers
SOURCE: i have a dell optiplex gx620 and it wont turn on
As you can imagine, this is not simple thing to diagnose.
First, we need to try Dell's steps to fix...
Remove non-essential peripherals…
Except for the monitor, keyboard, and mouse, remove all external peripherals including:
  • Scanner
  • Printer
  • Modem or Network cables
  • Personal Digital Assistant (PDA)
  • USB flash drive or other external Hard Drive
  • Any other external devices (e.g., USB-attached devices)
  • Remove the computer from the docking station, if you are using one
  • Scanner
  • Printer
Try rebooting. If that doesn’t work, Dell states you need to do the next step.
Remove and Reseat Basic Hardware items:
  1. Power Cord
  2. Memory
  3. Hard Drive
At this point, Dells says if that fails contact them.
If my hunch is correct, you may have something on the motherboard shorting a connection or you have a blown capacitor. Get some “canned air” and blow out the computer thoroughly. Some people have reported the same symptom having dust or other debris causing the issue, so give it a good blowing out,
At the same time, inspect your motherboard thoroughly for an anomalies. If you see anything resembling the picture below, you have a serious motherboard problem which will require replacement.
Posted on Oct 20, 2009
yngwei50
  • 134 Answers
SOURCE: Adding network drivers to dell optiplex gx620
Just download the drivers here the link http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=PLX_PNT_P4_GX260
Posted on Dec 18, 2009
SOURCE: How to open the case
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtcvrop0.htm#wp1051283
Posted on Mar 08, 2010
  • 113 Answers
SOURCE: Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Posted on Jul 14, 2010
Bios update gx620 dualcore
http://www.dell.com/support/drivers/us/en/19/DriverDetails/DriverFileFormats?DriverId=R142230&FileId=2731114925&productCode=optiplex-gx620&urlProductCode=False
May 04, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Bios update
BIOS updates are not necessary unless you have hardware compatibility issues or hardware related system instability. To obtain the most recent version of your BIOS (or any other downloads or info), go to Dell's website, click support and enter your model number, and it will show you anything you might need. Here is a link to the most recent BIOS update: http://www.dell.com/support/drivers/us/en/04/DriverDetails/DriverFileFormats?c=us&l=en&s=bsd&cs=04&DriverId=R106056#3DOSJust download the file and run it. It will do all the work for you!
Jan 07, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
Dell Optiplex GX620 says no sound card installed
check in your control panel and see if you are missing the drivers. if you are go to the dell website and download and update them.
Feb 09, 2011 | Dell OptiPlex GX620 (GX620P434MAR12) PC...
Just looking for the motherboard manual and cd for a dell optiplex gx620. I'm learning about my computer.
You can download the manuals for your OptiPlex GX620 PC directly from the Dell website here:
http://support.dell.com/support/edocs/systems/opgx620/en/index.htm
Oct 17, 2010 | Dell OptiPlex GX620 PC Desktop
For save old bios and install new bios Dell OptiPlex gx620 (from version A05 to A011)
If you are looking to update your BIOS then you can obtain the latest version from Dell. There should also be a step by step guide on how to correctly perform the upgrade. However, unless there is a real need to upgrade your BIOS then you should not have to do this. I have worked on and custom built several PC's and have never had to update the BIOS.
Oct 09, 2010 | Dell OptiPlex GX620 PC Desktop
Jul 14, 2010 | Dell OptiPlex GX620 PC Desktop
Dell Optiplex GX620 will not recognize firewire controller card
1394 drivers should be native to XP, you may be able to correct this by running an SFC scan
Take out the IEEE1394 card
Insert your Windows CD (if you do not have it order a backup from dell)
Exit out of 'install screen'
click Start
click Run
type 'sfc /scannow'
press enter
you should see a progress bar, when finished restart the computer
this compared critical windows files on harddrive vs CD, and replaces missing and corrupt files
Feb 03, 2009 | Dell 2-Port IEEE 1394 FireWire CardBus PC...
Dell OptiPlex GX620 PC Desktop Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
