Question about Toshiba MK5065GSXN - Hard Drive 500GB 2.5" SATA 5.4K
Toshiba mk5065gsxn smart failure
What should i do....??hw long would it work before the complete failure....??
  • Toshiba Master
  • 27,725 Answers
That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual.
Those things predict a hard drive crash, however it could take months for the drive to fail
(or it could be the next minute).
since it's a hardware problem the drive is going to die on you and you will have to replace it.
Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive.
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now ,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive
Hope this helps.
Posted on Nov 30, 2012
I plugged in a 120gb internal toshiba mk1234gax hdd2d16 hard drive and when turn laptop on it says SMART failure predicted on hard disk. how should i go about fixing this
Try turning off SMART in MotherBoard Settings (BIOS Settings) and if it won't work, Call a Computer Professional. If Warranty is alive, Call Authorized Service Center.
Mar 29, 2014 | Toshiba MK1234GAX 120GB 5400 RPM 8MB Cache...
Toshiba satellite pxe-m0f
I would check the hdd is OK and not full of errors. When you press F8 just before boot can you select restore? If you can the restore partition is OK and it will restore itself to factory condition. If you can't, re run your restore discs or use an OS disc and install drivers when you get online.
Mar 19, 2014 | Toshiba MK5065GSXN - Hard Drive 500GB 2.5"...
Toshiba mk5065gsx
Your hard drive is dying. It is time to clone it to a good working hard drive. Do it as soon as possible before it completely died.
Feb 26, 2014 | Toshiba Computers & Internet
Software problem
SMART is the system that monitors the health of a hard disk, in your case  it's close to complete failure. Follow immediately what that warning message says - copy all your data to some DVD's, replace the hd and reinstall.
Oct 31, 2009 | Toshiba Satellite U300-ST3091 Notebook
My toshiba satalite p300 wont work. this is what it says on the screen : SMART failure
The purpose of S.M.A.R.T. is to warn a user or system administrator of impending drive failure while there is still time to take preventative action, such as copying the data to a replacement device. Approximately 64% of failures can be predicted by S.M.A.R.T.[2] Work at Google on over 100,000 drives has shown little overall predictive value of S.M.A.R.T. status as a whole, but suggests that certain sub-categories of information which some S.M.A.R.T. implementations track do correlate with actual failure rates – specifically, in the 60 days following the first scan error on a drive, the drive is, on average. If you can not get the comp to boot, you may need to replace hard drive and reinstall OS and software.
Jan 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba MK5065GSXN - Hard Drive 500GB 2.5" SATA 5.4K Logo
683 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
